Browse Forums Building A New House Re: Garage wall height on boundary 2Mar 18, 2011 4:37 am This looks like the typical detail used on garage walls on boundaries to avoid the guttering overhanging you neighbours property. If you don't like it you need to move the garage wall off the boundary. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Garage wall height on boundary 3Mar 18, 2011 12:35 pm It looks like they have moved the eaves up a little everywhere, and altered the roof to match. Maybe they just changed the way the garage wall height is calculated, as it change from "3090mm average height of wall face brick" to "2988mm garage wall height on boundary". I'm surprised the garage eaves look the same on elevation A in the "after" pic though. Seems odd. If you look at elevation D, the garage eaves have definitely gone higher. I would be asking for clarification on that. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Garage wall height on boundary 4Mar 18, 2011 3:08 pm btherl I'm surprised the garage eaves look the same on elevation A in the "after" pic though. Seems odd. If you look at elevation D, the garage eaves have definitely gone higher. I would be asking for clarification on that. Yes... about that.. sorry should have mentioned in the original post.. the builder forgot to put the eaves on the garage in the Elevation A 'Before' drawings. Re: Garage wall height on boundary 5Mar 18, 2011 6:49 pm Our nextdoor neighbour built his garage on the boundary and was required to get us to 'sign off' on it because it was over 3m high. Could this change be due to the same thing? They changed the height to comply. Re: Garage wall height on boundary 6Mar 19, 2011 2:03 pm Yes, our estate had a max 3.0m average height requirement as well otherwise we needed permission from all and sundry. They dropped the garage by about 86mm to make that happen. Just means that the garage has a step down from the house, no biggy. SK Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16325 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17194 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7108 |
