Browse Forums Windows & Doors Re: Powder coating on window scratched during installation?? 2Mar 09, 2011 3:20 pm bella13 Hi, We got new windows installed as part of our reno - the old ones were oxidized aluminium ones from the 70s... Anyway when our carpenter put in the new ones about 50% of the windows ended up with about a 0.5cm x 2cm scratch in the powder coating... looks like it was from the sliding handles bit. We live about 2km from the ocean... Should I be worried about these scratches??? Is it going to cause problems down the track?? Is there any way to fix it? Thanks for your help - look forward to hearing from you guys!! Won't be an issue if you spray paint it now... check out Alspec for matching colours in spray cans... Find one near you... http://alspec.com.au/ Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Powder coating on window scratched during installation?? 3Mar 19, 2011 8:05 pm I would suggest using a polyurethane or automotive paint to touch up with. Generally, the coating in aerosol cans is not of the same quality as the original powder coating and will fade a lot sooner. This will make the repair look very obvious in a couple of years time. Re: Powder coating on window scratched during installation?? 4Mar 19, 2011 10:17 pm 86Craig I would suggest using a polyurethane or automotive paint to touch up with. Generally, the coating in aerosol cans is not of the same quality as the original powder coating and will fade a lot sooner. This will make the repair look very obvious in a couple of years time. I disagree... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Powder coating on window scratched during installation?? 6Mar 25, 2011 12:35 pm 86Craig put it this way - if your brand new car turned up with a scratch in it, would you let the dealer fix it with a spray can? do it properly and you won't regret it. Windows are powdercoated, cars aren't, the spray packs are excellent for touching up powdercoat, and they last. IMO. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Powder coating on window scratched during installation?? 7Jul 15, 2020 12:02 pm bella13 Hi, We got new windows installed as part of our reno - the old ones were oxidized aluminium ones from the 70s... Anyway when our carpenter put in the new ones about 50% of the windows ended up with about a 0.5cm x 2cm scratch in the powder coating... looks like it was from the sliding handles bit. We live about 2km from the ocean... Should I be worried about these scratches??? Is it going to cause problems down the track?? Is there any way to fix it? Thanks for your help - look forward to hearing from you guys!! This is a serious problem!The ocean moisture will damage the powder coatings around the scratches first then all way around.Did you buy these windows from China ? Re: Powder coating on window scratched during installation?? 8Jul 15, 2020 12:27 pm TagerD bella13 Hi, We got new windows installed as part of our reno - the old ones were oxidized aluminium ones from the 70s... Anyway when our carpenter put in the new ones about 50% of the windows ended up with about a 0.5cm x 2cm scratch in the powder coating... looks like it was from the sliding handles bit. We live about 2km from the ocean... Should I be worried about these scratches??? Is it going to cause problems down the track?? Is there any way to fix it? Thanks for your help - look forward to hearing from you guys!! This is a serious problem!The ocean moisture will damage the powder coatings around the scratches first then all way around.Did you buy these windows from China ? Not a problem, easy fix. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 7118 do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28401 |
