Browse Forums Owner Builder Forum Re: How would you fix this hole in the door? 6Mar 03, 2011 2:34 pm https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: How would you fix this hole in the door? 7Mar 03, 2011 9:22 pm should be able to get a door off ebay for under $20. Or you could ring some demolition yards to see if they have any. The should have something that will look close to what is there. Then a handy man to re mount it. Might need a clean up on the hinge side and also to patch the hole in the jamb. You'll have to make a new hole in the jamb for the striker. Re: How would you fix this hole in the door? 8Mar 04, 2011 6:08 am any half decent hardware supplies shop should carry these doors, espescially if they supply the trade, should be about $50, your problem will be to match the varnish finish, it will most likely look different to the esisting doors even with taking the best care. I'll take a guess & say $375-400 from the bond woodchip Re: How would you fix this hole in the door? 9Mar 04, 2011 10:18 am Woodchip stick a large plaque or coat hook over it on a batten can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4523 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 19150 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8859 |
