Browse Forums Bathrooms and Laundry Re: Extractor fan directly above shower 4Jan 24, 2011 4:59 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Extractor fan directly above shower 5Jan 24, 2011 7:30 am Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: Extractor fan directly above shower 7Jan 25, 2011 8:07 am ^^^^^ If the fans is working properly then the mirror won't fog up as the fan will extract all of the stem. I'm pretty sure the 3 in 1's aren't meant to go above the shower directly. FWIW you can get a heat lamp/light combo without fan if you want the heat lamps and then just get an extractor fan for above the shower. Re: Extractor fan directly above shower 8Jan 25, 2011 8:28 am if a three in one doesn't work properly or any other fan for the matter its because there is not enough air going into the room. Ie the gap under door may be to tight. The location of the fan doesn't matter as long as it is in the roof. If the fan needed to be above the shower then to use this theory our ducted heating wont work very good. Re: Extractor fan directly above shower 9Jan 25, 2011 5:16 pm chrisandkate I'm pretty sure the 3 in 1's aren't meant to go above the shower directly. Correct, 3 in 1's should go outside where you stand to dry, which BTW is the only time the heat lamps should be on. They are wasting power if on whilst you are showering as their ability to heat a room is poor as they are intended to heat a person directly under it. Re: Extractor fan directly above shower 10Jan 25, 2011 5:26 pm I think we have this extraction thing under control in our bathrooms. We have and extractor fan directly over the shower, a 3 in 1 in middle of the room, lights above the mirrors and a heating duct too!! My bathrooms don't get steamy, mouldy or cold! Oh and they can be lit up like a runway too if I want!! Re: Extractor fan directly above shower 11Jan 25, 2011 6:04 pm I agree with Stormy,I have exhaust fan over shower plus 3 in1 have never and I mean never had mould or fog on mirror.I do leave fan on while I dry myself,when builders started puting 3 in 1 in they did away with fan over or near shower.With high ceiling I don't think 3 in 1s work that great[only an opinion]ps i also have duct in main bathroom in winter i use it.
Re: Extractor fan directly above shower 12Jan 25, 2011 6:12 pm Fairy Blue,just read your comment about runway I know what you mean Re: Extractor fan directly above shower 13Jan 25, 2011 9:04 pm fairy blue I think we have this extraction thing under control in our bathrooms. We have and extractor fan directly over the shower, a 3 in 1 in middle of the room, lights above the mirrors and a heating duct too!! My bathrooms don't get steamy, mouldy or cold! Oh and they can be lit up like a runway too if I want!! You lucky thing. So jealous of you I want a heating duct too! Re: Extractor fan directly above shower 14Jan 26, 2011 7:37 am To tackle the airflow problem in our bathrooms I fiited an exhaust fan and a wall mounted 30cm fan. Leaving the window open helps with airflow, pulls air from outside that goes up into the ceiling. No 3-in-1 combo fitted here-things would be bad if I needed a heater in Darwin. Result-no mould, the walls stay dry and it always smells fresh in the rooms. Re: Extractor fan directly above shower 15Jan 26, 2011 8:48 am fairy blue I think we have this extraction thing under control in our bathrooms. We have and extractor fan directly over the shower, a 3 in 1 in middle of the room, lights above the mirrors and a heating duct too!! My bathrooms don't get steamy, mouldy or cold! Oh and they can be lit up like a runway too if I want!! Just like my setup, FB ...only we didn't get a heating duct installed (I should know better than to listen to my husband when it comes to heating - I swear, the man is part eskimo ), so we have a nice simple panel heater on a timer. When I swan into the bathroom in winter, it's a toasty 21C. And then I turn the overhead heat lamps on as well. Bright.... The heated towel rails (also on timers) make sure the towels dry too. No steam or mould here either. Re: Extractor fan directly above shower 16Jan 26, 2011 9:49 pm Thank you all for your responses. We will stick with a 1in3 in the centre of the room. Fingers crossed that we don't get any mold Re: Extractor fan directly above shower 17Jan 28, 2011 9:19 am kek .... The heated towel rails (also on timers) make sure the towels dry too. Wish I'd thought of heated towel rails. Although with all the heating I have in the bathroom, the towels dry quickly even in winter but they're not toasty warm. Re: Extractor fan directly above shower 18Jan 28, 2011 9:33 am I have a 3 in one in the centre but we will be putting another fan closer to the shower entrance come winter when we don't have windows open. The fan doesn't cope without windows open bugger! Re: Extractor fan directly above shower 19Jan 29, 2011 11:23 am We're having a 3in1 in the centre of the room, 4 downlights around it, and a seperate fan above the shower area Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Extractor fan directly above shower 20Jan 29, 2011 11:27 am That's what I have plus heating duct in floor My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5124 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1215 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20580 |
