Browse Forums Building A New House Re: So we're building! Weighing up options - Blackburn (Melb 5Jan 17, 2011 8:31 am Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: So we're building! Weighing up options - Blackburn (Melb 14Jan 24, 2011 7:45 am I feel your pain. Have had and still in some ways having the same problems ,but we're only a couple weeks away from knocking down the old one. Keep your chin up and it'll work out. Remember that a few little tweaks may not seem like much, but it could mean the difference between liking and loving your new home. Re: So we're building! Weighing up options - Blackburn (Melb 15Jan 24, 2011 8:50 pm Hi, I think with all volume builders it really depends on who your allocated supervisor is. If you get a great supervisor then the whole build will progress with hardly any problems (this happened when I built with Dennis Family). I am about to build with NBG. I did find that the progress was a bit slow getting the design changes sorted out, and with getting thru all the stages to get to the stage where the building permit is ready to be applied for. My cousin was also planning to build with NBG and had paid her $1000 deposit. She changed her mind, but because she had not progressed to the estimation stage they quickly refunded her deposit in full without question. I have heard good things and bad things about NBG, but that will be the case will all volume builders. As a safety net I will be using an independent building inspector to make sure everything is completed correctly. Good luck! Michelle House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Re: So we're building! Weighing up options - Blackburn (Melb 16Jan 24, 2011 9:58 pm East_Melb_Build We have a 15 meter frontage but a 45 meter deep block. Problem is, I really want car access down one side - so I need a home design which is about 10 meters wide (or has a drive through garage). Also because part of the appeal of our street is the traditional historic homes, I want to ensure what we build is sympathetic and complementary to that. We're after a largish home but also have some issues which mean we need a single storey home, and you can see why we're struggling Our block size is roughly the same (we rebuilt in whitehorse council) but had a rear and a side easement which means our house width was restricted. Still, we got a decent sized house on, with the double garage and drive-through access to what's left of the backyard (not much!). A large single storey on a 15m frontage is going to be a little tricky for most volume builders. I'd go for the drive through garage solution, though you probably won't fit a boat or caravan to the back if that's what you're thinking. While reputation of companies as a whole is something to take into account, what will contribute 99% to your finished house quality is the site supervisor and the quality of the trades he/she employs as mentioned previously T&T Knockdown and rebuild - building Metr1con Nolan 41 (43) @ http://tim-and-tina.blogspot.com! http://www.verdantdental.com.au Re: So we're building! Weighing up options - Blackburn (Melb 17Feb 05, 2011 5:40 am So the second quote is in - and I'm now waiting / get quotes from 2 more builders. I love the way everyone has a different opinion. One place is saying slab, another pillars and posts etc. I know I will never be able to 100% compare apples with apples, but hopefully I'll get some sort of idea... Re: So we're building! Weighing up options - Blackburn (Melb 18Feb 05, 2011 6:50 am To get what you want perhaps you need to develop your ideas sketch so its more like a definite floor plan The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: So we're building! Weighing up options - Blackburn (Melb 19Feb 05, 2011 7:00 am Thanks Bashworth - have done that (pics in the custom design floorplans thread) Even then, though, different builders seem to want to construct it differently! Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12299 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6720 Howdy all. I am looking for feedback on what people would do to maximise and make an area as flat as possible. First, out the front of the house is a sloping hill, pretty… 0 20450 |
