Browse Forums Bathrooms and Laundry Re: to anyone who has installed flick mixers! 3Jan 15, 2011 8:44 pm Where you are coming from is where you are going to... Re: to anyone who has installed flick mixers! 5Jan 15, 2011 8:50 pm onc_artisan No! should be able to remove and change hot/cold flexi pipes. Re: to anyone who has installed flick mixers! 7Jan 15, 2011 9:10 pm joeylucy great, do you think it's unreasonable to ask him to fix it? Re: to anyone who has installed flick mixers! 8Jan 16, 2011 4:58 pm they have to fix it. Fingers crossed the plumbers dropped the water down the top plate and not via the walls. If they did this it will take about half hr to fix. If it went via the walls they will have to cut the tiles out OR if there is only plaster wall on the other side they can cut the plaster and fix it from behind. Had to do this last week apprentice did the same thing. Lucky a rule of ours is everything must dropp straight down from the roof. good luck. but make them fix it Re: to anyone who has installed flick mixers! 10Jan 17, 2011 8:13 pm you are right. most even have a H on the left side and a C on the right.... The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15844 Hi All, we are starting to think of building with Masterpiece Builders in Victoria, has anyone had any feedback or experience with them 0 13753 Hi we are looking to talk to people who have built with them recently. We have signed mid range built contract but identified that a lot of things are not included.… 0 757 |
