Browse Forums Landscape & Garden Design Re: Advice on our new lawn please Fu! 7Dec 23, 2010 3:23 pm First_Timer_Ray I have to say, that's a pretty good effort in a DIY seeded lawn. It is nice even coverage and level too. Shame it's just not the right sort to be useful in Summer. Are any of the warm season grasses available as seed that you could oversow with? Then you would have great grass year round. Thank you!!! Your comments do make me feel a little more positive, and I will definately look into oversowing with a warm season grass! Can that just be thrown over the top of what is already there?? Build thread: viewtopic.php?f=31&t=32574 Re: Advice on our new lawn please Fu! 8Dec 23, 2010 3:28 pm I mix my molasses with seasol and powerfeed in a Seasol sprayer and off it goes I have backed it off due to so much rain and warm temps as the grass is growing TOOOO FAST! Also get some seamungus in there I think you are going to either oversow with a warm season grass short term really need to get the soil structure going for best results as it will cost you more in the long term with water usage if those roots are just in the topsoil layer I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Advice on our new lawn please Fu! 9Dec 23, 2010 3:29 pm any chance of a garden in the future??? I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Advice on our new lawn please Fu! 10Dec 23, 2010 3:34 pm mecha-wombat I mix my molasses with seasol and powerfeed in a Seasol sprayer and off it goes I have backed it off due to so much rain and warm temps as the grass is growing TOOOO FAST! Also get some seamungus in there I think you are going to either oversow with a warm season grass short term really need to get the soil structure going for best results as it will cost you more in the long term with water usage if those roots are just in the topsoil layer Thanks..... so the molasses/seasol/powerfeed/seamungus treatment will get the soil structure going??? mecha-wombat any chance of a garden in the future??? And Yes! There will be a garden!! Wanted to the grass growing first!! Why? Do you have tips or ideas 4 me?? Build thread: viewtopic.php?f=31&t=32574 Re: Advice on our new lawn please Fu! 11Dec 23, 2010 4:10 pm It is actually much easier to establish garden areas first and then lawn, much less work intensive. One good thing is that the grass you have used should be easier to eradicate from garden areas. I have thought a lot about imroving soil under lawn as I discovered this forum after lawns were already in, and the liquids and other stuff on top is good but I would like to get zeolite, spongolite and clays deeper into my soil profile. This is how I plan to do it. I am going to give the lawns a good week of watering to get moisture deep into the soil so it "stands up" (as it is sand). Then I paln to hire a coring machine and intensivly core out plugs, removing them and backfilling with mixture of fine compost, clay (bentonite or similar), zeolite and spongolite. Then I am going to topdress with a 50/50 mix of fine compost and yellow sand to smooth out and level up as I have a few uneven contours. Then, when the lawn has repaired itself I will repeat the process trying to aim the cores in between the previous ones. And so on. Worth a try I reckon. In your situation I would buy some Empie Zoysia turf rolls and cut up into strips and plant in, but only in the areas that you want to ultimately be lawn. Waste of resources otherwise. Spray out the current grass and get garden beds in ASAP in areas to be garden, cut down your mainance regime. PS - Plan out your yard first, work out where your hardscaping/ sheds/ vege patch/gardens/ sacrificial alter/ whatever/ are going to be, and what is going to be lawn, only establish lawn in that bit. Use a low maintanence stabilising solution for the rest until you can develop it. (That's how I would go about it anyway) Re: Advice on our new lawn please Fu! 12Dec 23, 2010 5:00 pm First I would check the pack to see what exactly is in the seed mix, I cannot see any couch or kikuyu in that, although a close up would be handy. If it does not contain a warm season grass, you could hit it with a steel rake and lightly top dress it and then throw down some of my all time favourite grass kikuyu. Re: Advice on our new lawn please Fu! 13Dec 23, 2010 5:30 pm What brand seed did you use? Check the box/bag seed purity it looks like the annual rye grass is dying off which is what it's supposed to do, it acts as a cover crop to protect the stronger grass. Depending on the brand you could have Bermuda grass (couch) underneath. Re: Advice on our new lawn please Fu! 14Dec 24, 2010 12:13 am Yep, all you can do it use molasses, powerfeed, compost teas. Make sure you use saturaid if the soil doesn't absorb water (not like you'd have that though with all the rain). Apply zeolite if you can. The use of these turfs is a sensitive issue for me. I am fortunate to get an in depth knowledge of the greater picture when it comes to what these turfs do to our resources and what affect pesticides and fertilizers are having on our environment. There is no magic wand or single product on its own that will solve the problems. A bunch of them will work together to sort of make things better. That way you are doing the best you can with what you have. If you must use seed, then use the Emerald Kike. Re: Advice on our new lawn please Fu! 15Dec 24, 2010 12:16 am There is much more that can be done but I may not have the audience for it the leaves that are now underground go yellow, the tips that poke through photosynthesise and have chlorophyll, same reason they grow rhubarb in the dark. 5 4994 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 19225 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 6051 |
