Browse Forums DIY, Home Maintenance & Repair Re: Oil versus Acrylic paints 2Dec 24, 2010 8:36 pm The reason oil based paint yellows over time is lack of UV light they are still better than acrylic IMO as they are harder wearing and not affected by warm temps (thermo plastic) I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Oil versus Acrylic paints 4Dec 24, 2010 8:52 pm They slow it down but will still yellow over time The back of wardrobe doors can yellow severely in the space of 12 months I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Oil versus Acrylic paints 5Dec 24, 2010 9:34 pm I can't really comment in detail on oil versus acrylic but can advise that I have used acrylic paints of every gloss level for over 30 years, indoor and out, and found them to be a a reliable, durable, effective surface protection for timber. Their only downfall in my mind is that you can't apply in low temperatures, say less than 15 c - it will just sit there until the temperature rises before it dries! I also note that the acrylic paints tend to corrode their paint cans, so I'm always a bit cautious about painting directly onto bare metal - I would probably use oil paints on metal. If you must have a high gloss, then you might have to use oil paints - but if all you're looking for is a washable, hardy paint then my first thought is always acrylic. Thanks, OzzyJack Re: Oil versus Acrylic paints 6Dec 27, 2010 8:56 am Thanks ozzyjack....I think the acrylic paints rust the paint tins at a greater rate than oil because they have a higher water content. Bare metal should be primed with an oil based primer...I think water based paints are easier to use but don't quite give the gloss look as well Re: Oil versus Acrylic paints 7Dec 30, 2010 4:43 pm From what I can gather, oil paints yellow, are tougher and go on well. Acrylic paints don't yellow, chip more easily and leave streak marks. The painter will also prefer acrylic paints since the brushes/rollers just wash out in water. Also, if yoou want the highest gloss level, then only oil paints will achieve this. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Oil versus Acrylic paints 8Jan 05, 2011 10:15 am hey guys imo oil is better, lol. umm yes it does yellow how ever you can combat it by getting black added to the tint, if you go pure untinted white then yeh it will yellow in 6 months, but if you were to add 2 or 3 parts black then up against white its grey but to the naked eye its white. most to all ceiling are grey but they look white. acrylics have come along way dont get me wrong but i feel even though the surface may have been acrylic glossed or aqua enameled it still doesn't look " Finished " if you know what i mean. i believe acrylic glosses should be used for exterior of house not interiors, if you have fold out windows or ledges etc yeh put acrylic gloss on them to highlight it as the uv tolerance is higher than enamel and it wont chalk out, but thats me hope that helps Glenn Re: Oil versus Acrylic paints 9Jan 15, 2011 8:15 am Lexicon comes to mind 1% black o white however I find it too cold of a colour personally would add some red to it too. Acrylic paints do not flow out of the brush easily as oil base paints so oil base can smooth out after application acrylic need s some additives for easy painting however tends to leave more visible paint brush streaks on wood. Glennb hey guys imo oil is better, lol. umm yes it does yellow how ever you can combat it by getting black added to the tint, if you go pure untinted white then yeh it will yellow in 6 months, but if you were to add 2 or 3 parts black then up against white its grey but to the naked eye its white. most to all ceiling are grey but they look white. acrylics have come along way dont get me wrong but i feel even though the surface may have been acrylic glossed or aqua enameled it still doesn't look " Finished " if you know what i mean. i believe acrylic glosses should be used for exterior of house not interiors, if you have fold out windows or ledges etc yeh put acrylic gloss on them to highlight it as the uv tolerance is higher than enamel and it wont chalk out, but thats me hope that helps Glenn The yellowing mainly occurs to white or very light colours. 1 2942 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1933 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10971 |
