Browse Forums Kitchen Appliances 1 Dec 20, 2010 11:29 am For those who have wall ovens, how high is yours? How tall are you? Do you have a microwave or perhaps another oven above it? How low is your bottom wall oven? Re: Wall ovens - how high/low is yours? 2Dec 20, 2010 12:16 pm Just too a look at our plans. It doesn't specify the exact height but it looks like our 600mm wide Oven is 800mm from the floor at the bottom of the oven and 1400mm from the floor at the top. We will have a microwave provision above the oven. I'm 6'2" and the GLW is 5'5"ish Re: Wall ovens - how high/low is yours? 3Dec 20, 2010 10:45 pm hi they had drawn ours finishing 300mm off the floor ( duo oven with m/w on top) , i thought this was way too low , so created another stack next to it too have m/w and oven next to each other. And three draws undeaneath. I was more worried about it being too low for my kids to play with Re: Wall ovens - how high/low is yours? 5Dec 21, 2010 3:27 pm Good point yvonnemmm. Not much point in having a wall oven when it is that low, is there. 4 6193 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17525 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13735 |
