Browse Forums Kitchen Corner Re: flat pack kitchen 5Dec 03, 2010 12:16 am Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: flat pack kitchen 10Dec 15, 2010 3:44 pm where abouts are you located? I have found a bit of variance but i am surprised to hear that there where not hinge holes in the doors! One place i have used in the past the only hole you had to drill was to install was the door handle ever other thing was pre drilled. Re: flat pack kitchen 11Dec 15, 2010 8:22 pm rjm After that, we decided to get a quote on build and fit (to our own design) a complete kitchen and it actually worked out a lot cheaper than getting another ******* flatpack. There are lots of kitchen mobs around nowadays and the prices have come down considerably. Hope this helps. There are also a lot of flatpack kitchen companies that do good packs, at a reasonable price and don't play tricks such as what you encountered. Haven't done a kitchen as yet, but have used the company below for wardrobe inserts and found them to be top notch. Interestingly they talk about hinges etc and leave it up to the customer to decide if they want pre-drilled or left as is. I would only use a company like this if I knew exactly what I was doing though. That is I knew what I wanted and how it would all fit together. http://www.cabinetsondemand.com.au/ I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4094 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13836 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7114 |
