Browse Forums General Discussion Re: Rendering the exterior of my new home 5May 07, 2008 7:54 pm that's a good idea, we want to do out house in the future also, unfortunatlely the previous owners painted the house white so we have to get that off and then do the rendering, i have priced the stuff up at bunnings to do it myself, i would be alot from the hip pocket and also the elbow grease to match would be easier to get some one in!!!! - but that is a long way off for the minute!!! Re: Rendering the exterior of my new home 6May 07, 2008 8:10 pm Patchie that's a good idea, we want to do out house in the future also, unfortunatlely the previous owners painted the house white so we have to get that off and then do the rendering, i have priced the stuff up at bunnings to do it myself, i would be alot from the hip pocket and also the elbow grease to match would be easier to get some one in!!!! - but that is a long way off for the minute!!! I would get advice from a professional renderer for this! Trust me, if not done properly you could have a house with more lines and cracks in it than a road map! Get some quotes, and then milk them for some info while they are there. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Rendering the exterior of my new home 7May 08, 2008 8:55 am There is definately an art form to rendering. Fair enough if you were going to try rendering a feature wall in the backyard but your front facade...??? You can pick ******* render a mile off - it looks lumpy in sunlight. I would highly recommend getting a professional. Re: Rendering the exterior of my new home 8May 12, 2008 3:05 pm IMO, if I was building the house I would leave it brick. It's so maintence free and IMO, looks better. Depending on the product, the render should hold together for hairline crack as it is somewhat flexible, but bigger cracks will stand out and are very hard to patch without redoing the whole wall. Not that a new house should get any cracks this big. I would plan to paint it every 10yrs.
In saying this, I've rendered my house, but its a 30yr old house with grey besser bricks, so I see it as an improvement. Patchie - If the paint is sound, you can get a render that goes straight over. http://www.quikcote.com.au/Quikcote_Flexipatch.pdf Though I've never used this particular one, but I think its about $30 a bag. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4940 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7640 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5272 |
