Browse Forums Home Theatre & Automation Re: What TV antenna to install in North Brisbane area? 4Nov 10, 2010 9:55 am for a tiled roof it can go inside the roof... one more option.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: What TV antenna to install in North Brisbane area? 5Nov 11, 2010 8:48 am ![]() Hi, just purchasing a new house in north Brisbane and need to have a TV antenna installed for Free to Air. Does anyone have information on what type we need to install?? PAGE :73 .. http://www.clipsal.com.au/trade/__data/page/81/D75.pdf Re: What TV antenna to install in North Brisbane area? 6Nov 17, 2010 2:40 pm hi, it really depends on what kind of channels you're looking for...if it's greek channels, then you need K-band dish, 65cm, if it's Indian then it will be C-band dish which is big 2.3m...so if you want to find out what dish you need, google your free-to-air channels and read about what's dish required for getting these channels... Re: What TV antenna to install in North Brisbane area? 7Nov 17, 2010 3:03 pm ![]() hi, it really depends on what kind of channels you're looking for...if it's greek channels, then you need K-band dish, 65cm, if it's Indian then it will be C-band dish which is big 2.3m...so if you want to find out what dish you need, google your free-to-air channels and read about what's dish required for getting these channels... Other then the fact the OP is asking about FTA TV (Free to Air) not Satilite services Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal DIY, Home Maintenance & Repair Brilliant - thanks so much for that. I didn't want to start pulling too hard on it if there was some other way it was attached, but yep, it was just the paint sticking it… 2 3857 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 9037 ![]() The warning is on the sticker on the door too. Second the aluminium powdercoat 6 19363 |
