Browse Forums Building A New House Re: Things you forget 142Nov 01, 2010 9:07 am Building at Warner Lakes in sunny Queensland. Building with Bold Properties. Building thread is here! - https://forum.homeone.com.au/viewtopic.php?f=31&t=38957 Blog is here! - http://campoutforland.blogspot.com Re: Things you forget 143Nov 01, 2010 9:29 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Things you forget 145Nov 02, 2010 9:09 am We're building The Albany 330E with Casa Design & Construction via National Builders Group See how we are going here: https://forum.homeone.com.au/viewtopic.php?f=31&t=32694 Re: Things you forget 150Nov 08, 2010 4:26 pm OurLindrum52 We were quoted something ridiculous for soft-closing drawers sp dropped it. However, try Tim & Tina on this link as he has found one you can fit yourself easily.... http://www.tim-and-tina.com/ Wow thanks for that!! I’ll definetly show my husband, they look really good! I also thought of more stuff - sorry if some of these have already been mentioned: 1. Extend your garage if possible. We only extended ours to 6m x 6m and it makes all the difference. Possibly consider adding a storage/workshop space as well. We are so glad we did – clears all the clutter away from the cars. 2. Got a front loader washing machine? Consider running your laundry bench the whole way across your laundry. Makes the laundry look more neat and streamlined and I love the extra bench space for folding clothes etc. 3. I added a clear space of 450mm in my laundry to hold a clothes basket. Don’t forget to tell the tiler not to tile this space! We forgot to mention it to the tiler and this space was tiled with skirting tiles so DH had to trim my clothes basket to fit to accommodate the extra width of the tiles layed in that space. 4. Check your building specifications Contract and see what it states about skirting for your tiles. Most builders use your floor tile as the skirting tile and only tile skirting to 200mm. If you want full height skirting, you may have to buy these extra as (imo) full height skirting looks better. 5. Perhaps include a letterbox in your building contract. We only paid $250.00 for ours (brick, rendered and painted) and it was well worth it for us. If you’re thinking of using the leftover bricks and constructing one yourself after handover, possibly consult with your ss or builder to leave leftover bricks on site. All our bricks were taken away from site when bricking had finished and I think a few others have mentioned the same thing happening with their bricks. 6. Having your builder install a wall mounted clothesline for you? Check the measurement they have given you as our builder upgraded ours to a further 1m long and it was the same price as the smaller one. 7. Keep a diary or spreadsheet of all your dates (e.g. slab pour, frame delivered, frame started etc, etc) once construction starts. You don’t know when you will need to refer to it if something needs to be brought to the attention of your builders. Also keep a diary of dates and notes of phone conversations with builders/ site supervisors etc. 8. I also kept a spreadsheet of all costs paid and money spent associated with the build. You can then easily track exactly how much you have spent on your build overall , where your money has gone and if you need to refer to it, the date it was paid. Re: Things you forget 153Nov 11, 2010 9:52 pm Got Tender tomorrow, so figured this would be a good time to go back over the list. I'm pretty sure I forgot to include a solid door to the Xbox room. Shall write that down now Land Deposit - 18/12/2009 Became a land Baron - 21/12/2010 Site Start - 27/1/2011 All moved in!! Re: Things you forget 154Nov 12, 2010 8:52 pm A bit of a bugger, we just realised....we are installing a auto opener for our garge after handover and forgot to get the builder to put in a power point on the ceiling. we have a flat roof and is going to be a headache to get to it now! Re: Things you forget 155Nov 12, 2010 9:06 pm Ok,have just realized on plans that pantry door opens in. Not good,because you would have to close the door to get in behind it/to get to the rest of the pantry,DOH! Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Things you forget 156Nov 13, 2010 12:07 pm HI all If you are a photographer or just love lots of wall hanging get them to put in an extra row of nogging so you have a solid row of wood to hang to, not just plaster. Put in as many power points as you can and TV points its cheap now than latter. I would also recomend you do a lot more planing before you even think about building a house. KW........ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Things you forget 157Nov 13, 2010 5:57 pm With the electrical, i'd suggest also adding a conduit for whereever your foxtel is going. If it's on a cavity wall then they normally have no problem but if its not then it can be a pain. Add the conduit so they can run a TV and Phone cable down. The other thing, while wireless is OK nothing beats hard wired internet. Get CAT5 cables to all rooms that may need data points. Also, run 2 x data points from your main living area to all other areas that have a TV (so you can later introduce a LEAF video distribution system - or something like it). RE; the fridge tap - don't put the tap directly behind the fridge, put it inside the kitchen cupboards instead and just cut a hole for the water line later. Putting the tap and filter behind the fridge often won't let the fridge fit. Also, check measurements of your furniture etc.. (fridge is a good one) and make sure you allow 12mm for render on the walls AND make sure you allow for your floor coverings!! I've seen people have an 1800mm high fridge and look at the plans thinking it's OK, only to find they put plank on ply timber floors and the distance ended up being 1755 from the floor to the overhead cupboards. Re: Things you forget 159Nov 14, 2010 9:34 pm YBBroker - good point re tap behind fridge! Does anyone know how much space a tap will take up? We have a reasonable fridge space but I'd rather get it right before no more changes can be made to our plans! Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Things you forget 160Nov 15, 2010 12:23 pm and can that tap be fit not exactly behind the fridge but on a bit side - in same space as fridge goes in but in the sort of corner as there is normally some space between the side wall and fridge - i hope it makes sense what i am writing Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11762 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8503 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6733 |
