Browse Forums Building A New House 1 May 05, 2008 5:15 pm Re: Does Lockup include the garage door? 9May 05, 2008 6:09 pm dancelisah Does that mean they deliver all the internal doors before lockup to put the garage internal door on or just that one? Usually lock-up means the external doors. ie. Front door, laundry door if you have one and internal garage door. These might also be temporary doors? The internal doors will be delivered as you get closer to painting/fixing stage. Our builder had all doors delivered and painted at the same time, and our lock-up was with a temporary front door but if you're not too sure, it's better to ask your S/S? Different builders might time it differently. Re: Does Lockup include the garage door? 10May 05, 2008 7:28 pm External doors will be fitted and locked for lockup. Internal doors probably won't even be delivered until the fix - ours were delivered at the same time as the skirt and architraves.
No garage door - one of the later things to go on, due to the possibility of damage. Our house is at lockup, however the roof tiles haven't gone on the garage as yet (although ours is double storey). Locks will be keyed alike, however the lock installed at lockup will be changed before handover, so don't stress if the locks look a bit crappy! Cheers Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 6830 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6350 My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2674 |
