Browse Forums Flooring & Floor Covering Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 9Nov 02, 2010 1:07 pm Hey Jan, don't despair. If the tiles are generally neatly and well laid, I don't see a big issue with the 3mm grout line (from memory, just the other day someone was saying they paid extra for 1.5mm but got a poor job). So at least you didn't pay for the extra labour to achieve <3 mm. On the other hand, I could be totally wrong - so maybe posting a picture or two could help My signature is distracting people from my wise posts ... Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 10Nov 02, 2010 3:01 pm Hi Kineso - you're absolutely right! I'm thinking of making checklists that people getting their houses built should look through and tick off so that they do not fall in the same trap we did. We don't know what to ask/do because we felt we are in the hands of professionals and especially because we do not know what we don't know. So people really need to capture their tiling specification with all those details you mentioned. Atleast in your situation, they improved their customer service but in our case, they didn't even though there were a number of not so major mistakes prior. Hi Lex - Well, the tiles are laid neatly except for the edges where tiles weren't even cut straight and they were not tucked under the skirting board either. But I suppose only us owners will notice these things. I tried to post the picture but I get an error (not that I can remember what the message was) but I will try again later on today. Thanks to both for your response. I have been laying in bed trying to come to terms with the tile issue and reminding myself that it's only a house and only tiles. Atleast I have a "brand new house" to worry about which is not a bad worry to have. But what stings is the fact that we paid an extra $5,000 to get rectified tiles knowing that we needed rectified as a minimum to get 1-1.5mm gaps and not getting the seamless look for the extra $5,000 is just a waste of $5,000. But at the same time, as Eve Dweller pointed out, if we got it done with smaller grouting gaps, it would probably have costed us an extra $10,000 or more (rectified tiles + labour). And as Lex pointed out, I could still have gotten a poor tiling job. The great news is the director of the building company is kind enough to agree to meet us on site Saturday morning to go through all the mistakes that have occured and look over the tiling. Then we can see where to go from there. The issues only started once we were passed onto the customer service person. Will keep you posted. Not getting my hopes up though as it is most likely partly our fault as well. Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 11Nov 03, 2010 1:21 pm Firstly rectified tiles does not mean you have a smaller grout joint. Any size grout joint can be achieved with any tile porcelain or ceramic, cushioned edge or rectificated. Rectificated tiles give the illusion of a smaller joint as the grout is flush with the surface of the tile, not recessed with a cushioned edge tile. Yes...alot of clients do request tilers to using a smaller joint, but because its rectificated does not mean the smaller joint is only used. Secondly AS3958.1-2007 (Aus Standards) specify grout joints of 1.5mm to 5mm on walls and 3mm to 15mm on floors. So I think there has been a lack of communication between tiles, owners and the tile shop. I always explain the above to my clients. Charlie Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 12Nov 04, 2010 8:19 am What Charlie has said, its not a "given" to have a smaller grout joint just because you supplied rectified tiles. Unless it is a horrible tiling job, I doubt you really have anywhere to move on it with regards to having it fixed so to speak given you never specified how you wanted it layed in the contract. Unfortunately for you, I think you will have to chalk it up as a lesson learned. Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 13Dec 02, 2010 8:26 am I agree rectified edges does not create a seemless look. If a customer wants a small grout we advise them that sanded grout will just end up falling out, if you want skinny 1.5 mm joint than unsanded grout should be used but this creates maintenance issues as sanded grout is easier to maintain. If you want that seemless look you can still have it by grout colour sealing, grout perfect applicators can match the colour off your tile this will give you that seamless affect and 100 times easier to maintain. There will be new DIY kits available early next year for those who do not have an applicator near them or want to save on labour costs. Craig Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 14Dec 03, 2010 1:38 pm Keep in mind that you're the harshest critic of your new house and it's often never as bad as you think it is. You got me thinking "hmm I think I have 3mm-ish gap on my porcelain tiles, bugga!" but then I remembered that I thought it looked fine when I checked it last time . Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 15Dec 08, 2010 7:30 am Our porcelain tiles have just been laid. The tiler said he would do a 1-1.5 grout line. Well..............the majority of the house is about 3mm the rest is about 1.5mm. I also asked him at the time to seal the grout, but he said there was no need as the grout line is so small and he uses some antibacterial stuff in the grout so I shouldn't have any problems. Well last Friday, we had our final inspection and our SS said that we need to seal the grout as we will always have problems trying to keep it clean. So what do you think I was doing all last weekend.............sealing that bloody grout. On the up-side, the 3mm grout line doesn't look too bad as it is a very light colored grout. Barb Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 16Dec 08, 2010 8:16 am Hi Barb It is a clear penertrating sealer that you applied it water proofs your grout but in time say 2 years you will wonder why you even bothered, as clear sealers only give you enough time to treat a stain. It does nothing for soil build up but it does make it easier for a prof tile cleaner to clean. Most tilers and tile shops do not know this. This is why grout colour sealing was invented in the USA about 10 years ago and is now offered here in Australia it lasts 10 times longer than clear seals and repels any soil or liquid well over 15 years it is a lot more expensive but soon there will be DIY kits available from Grout Perfect. Craig Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 17Dec 08, 2010 6:37 pm Grout Perfect Hi Barb It is a clear penertrating sealer that you applied it water proofs your grout but in time say 2 years you will wonder why you even bothered, as clear sealers only give you enough time to treat a stain. It does nothing for soil build up but it does make it easier for a prof tile cleaner to clean. Most tilers and tile shops do not know this. This is why grout colour sealing was invented in the USA about 10 years ago and is now offered here in Australia it lasts 10 times longer than clear seals and repels any soil or liquid well over 15 years it is a lot more expensive but soon there will be DIY kits available from Grout Perfect. Craig Really? Not even the Aquamix's Sealers's Choice Gold Professional (clear sealer) can protect against stains? Seems like I should not bother My signature is distracting people from my wise posts ... Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 18Dec 09, 2010 7:35 am Clear sealers Aqua Mix or any other will protect against stains but only if you treat asap as it only water proofs grout as penertrating sealers loose there tension with in 12 months. You can seal it but do not beleive what it says on the bottle we have seen hundreds of floors that had been clear sealed and the customers always say why did I even bother. Craig Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 19Dec 09, 2010 8:12 am Jan Sorry for your problems. It just goes to prove you have to put every thing you want in writing. Assume nothing as if it can go wrong it will. I maded drawings of how I wanted the tiles to go, gave a copy to the colour selection girl and the builder. You need to show that you gave instructions to them, so put it down to expirience and remember " you cant buy expirience but you end up paying for it". Maybe the builder may compensate you with a few freebies, I hope so. Cheers KW........ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: $5,000 WASTED! Rectified tiles laid with 3mm & grey grou 20Dec 09, 2010 8:37 am How disappointing Sounds like you had a bad consultant but of course, as always, the onus is on us I'm sure your flooring still looks beautiful even if it's not quite the look you were after. Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19080 6 11528 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17774 |
