Are there any real differences between a $40 cable and a $180 cable?
I'm looking at a 10 meter cable and dont want to lose quality due to a crappy cable, but nor do I want to be screwed either.
Thanks,
Browse Forums Home Theatre & Automation Re: HDMI Cables 4Apr 14, 2010 2:21 pm ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: HDMI Cables 5Apr 14, 2010 4:47 pm Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: HDMI Cables 7Apr 15, 2010 2:35 pm ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: HDMI Cables 8Apr 15, 2010 4:26 pm Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: HDMI Cables 9Apr 15, 2010 4:52 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: HDMI Cables 14Oct 26, 2010 2:01 pm There is defnitely some difference in quality - I've had bad experiences with really cheap HDMI cables (basically just not working) like the ones that sometimes get bundled with some gear (cheaper Blu-Ray players for example). As soon as I swapped the cable for a Selby one (P.S. Ugly=Selby) - which in my opinion are also still very affordable compared to big brands like Monster, the problem was fixed straight away with the Selby cable. A 10m HDMI cable for $30 is cheap cheap - I personally wouldn't trust it... Re: HDMI Cables 15Oct 26, 2010 4:03 pm I wouldn't buy an el-cheapo hdmi cable for a 10m run (1-2m run? No problems, buy the cheapest). But a Selby et al at that distance would be fine. Once you start getting 15-20m, yeah, you need something decent, but even that doesn't have to be expensive, about $150 for a 20m cable. Re: HDMI Cables 16Oct 29, 2010 1:14 pm Soon we won't have to be using HDMI cables, even for runs up to 30'. wireless HDMI is coming... http://hothardware.com/Reviews/WHDI-Kit ... -HDelight/ Re: HDMI Cables 17Oct 29, 2010 5:31 pm HDMI wall plates ... Quote: Extends Full HD 1080p HDMI 1.3 signal up to 40ft Extends Full HD 1080i HDMI up to 80ft from the source Easy Installation with Standard Cat5E/6/7 cables Blue-Ray 24 FS/SV-YCC/DTS-HD support Sender unit converts HDMI signal to CAT5E/6/7 TMDS signal automatically Audio and video are transmitted digitally over two CAT-5E,CAT-6 or CAT-7 cable with no signal loss HDMI / HDCP compliant Easy installation with common tool Absolutely no AC/DC power require http://cgi.ebay.com.au/HDMI-Over-CAT5-6 ... 3361f689d0 Re: HDMI Cables 18Oct 29, 2010 6:03 pm Rodda There is defnitely some difference in quality - I've had bad experiences with really cheap HDMI cables (basically just not working) like the ones that sometimes get bundled with some gear (cheaper Blu-Ray players for example). As soon as I swapped the cable for a Selby one (P.S. Ugly=Selby) - which in my opinion are also still very affordable compared to big brands like Monster, the problem was fixed straight away with the Selby cable. A 10m HDMI cable for $30 is cheap cheap - I personally wouldn't trust it... I'd suggest the cheap HDMI are not HDMI certified and are probably made in China or similar intellectual property/standards ignorant country. They may carry the term, but from China that doesn't mean much. |
