HI,
Can any one shed some light on the best options for window opening ie double hung, tilt and turn etc? Can you recommend any?
We need cross ventilation and flyscreens, all on the ground floor.
Thanks
Sarah
Browse Forums Windows & Doors Re: Window openings 2Sep 27, 2010 4:31 pm Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: Window openings 5Sep 28, 2010 11:15 pm Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Window openings 6Sep 29, 2010 9:15 am Thanks Eskay40, I didn't realise it was soo big. Hope this is better. Is there a post on how to upload photos? Then I won't need to ask people to fix it for me!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Well, I guess casement windows are not an option, I don't want my kids falling off the veranda trying to get around open windows. Re: Window openings 7Sep 29, 2010 9:42 am Hi, there's a thread here for it http://forum.homeone.com.au/viewtopic.php?f=13&t=1272 You've done most of it by putting it into imageshack. You'll see a box on the right hand side, under the add next to your photo, where there is a direct link address - NOT the embed link. Copy that link. Come back into your message and use the full editor. Then, where you want to put your photo, press the "Img" button at the top of the editor, second last before the URL link. Without moving cursor or doing anything else paste in the link you copied. It should be pasted in between these "[img]inhere[/img]" Manually take your cursor out of that area once you've pasted the link and the photo should be there. You can hit Preview to see your message first to see if it worked. SK Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Window openings 8Sep 29, 2010 11:18 am Hi, Yes we have installed casements that open flat against the wall, but it's less to do with the window and more to do with the installation. Lets say you have brickwork protruding, the opened window will not open flat against the wall. You have to discuss with the installer your option. Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: Window openings 9Sep 30, 2010 1:02 pm So casement windows can open flat if they are installed toward the outside of the window 'hole'? great, will look into this. Another question: In family room I have two doors leading to south side which I would like to replace with double glazed doors, or is it much more expensive to change them to 1 window that is only half way down the wall (so I can put a couch under it) and then the other change to a bifold door with larger opening. Really, is making the openings different sizes going to blow the small budget I have? Hope this is not too confusing! Re: Window openings 10Oct 01, 2010 8:29 pm If your concern is kids falling out, but yearn to naturally ventilate your home, awnings or tilt & turn windows may be suitable. Tilt & turn windows have a vent that locks into position, and the window can't be fully opened (just like a casement without turning the handle. To purchase a double glazed door you will need to consider the installation charge as well as delivery fees (if there are any) from your preferred supplier, these can add up. It will be ok if you are ordering other windows and the door can be part of a complete order, but if you order it separately elsewhere it can be expensive. Double glazed bifolds are a concern operationally, because many standard hardware pieces have limited sash weight capacity. It is important to get good quality hardware, and if possible upgrade hardware to ensure trouble free operation. The hardware we use (for upvc double glazed bifolds) is specialised high traffic application hardware. I believe this is less of concern with aluminium profiles. Also, bifolds are generally a more expensive window/door type, so this may have a larger than expected effect on your budget. For the window, do you mean to get a door sized frame with fixed glass on the bottom and the opening sash at the top? Or do you mean to have brickwork there instead? Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: Window openings 11Oct 03, 2010 8:37 am We have tilt and turn- great for security, fly screens on the outside, clean them from the inside, strong. Also have an inward turn only on one- with a restrictor- so this could be your solution. Tilt and turn are the European norm- so no problem with children there! Sure you would be happy with tilt and turn- the strong mechanisms make other windows seem primitive and flimsy. Re: Window openings 12Oct 03, 2010 8:53 am sparks We have tilt and turn- great for security, fly screens on the outside, clean them from the inside, strong. Also have an inward turn only on one- with a restrictor- so this could be your solution. Tilt and turn are the European norm- so no problem with children there! Sure you would be happy with tilt and turn- the strong mechanisms make other windows seem primitive and flimsy. Many people don't like the exterior flyscreen solution for tilt & turn as they are a prominent feature on an otherwise aesthetically appealing window. The awning and casements all take clip-in internal screens. With regard to strength, in PVC, the T&T is the same as the rest of the PVC range, which is a lower N rating than aluminium (in our case - many aluminium windows don't perform as well as this), but there is no doubt it is a very good window. We sell all of these and have had them all tested. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Window openings 13Oct 03, 2010 9:49 am Our fly screens snug fit /clip very neatly into the frame- just like any other window, actually much better than most. Awning windows with screens on the inside can be very annoying, especially with blinds. This is definitely a much neater solution. German hardware is what I mean by stronger. Compared to much of what is used here. Re: Window openings 14Oct 03, 2010 10:01 am sparks Our fly screens snug fit /clip very neatly into the frame- just like any other window, actually much better than most. Awning windows with screens on the inside can be very annoying, especially with blinds. This is definitely a much neater solution. German hardware is what I mean by stronger. Compared to much of what is used here. Our casement/awning screens don't interfere with blinds etc... German hardware is good, but the local hardware passes the same tests in the whole window. It's the window rating that is important. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7516 |
