Browse Forums Landscape & Garden Design Re: SOAKWELLS - How easy are they to put in and install ? 22Jul 13, 2010 11:59 am Garden - viewtopic.php?f=19&t=44214&p=670323#p670323 Decorating - viewtopic.php?f=6&t=47218&p=715743#p715743 Re: SOAKWELLS - How easy are they to put in and install ? 24Jul 29, 2010 1:40 pm Garden - viewtopic.php?f=19&t=44214&p=670323#p670323 Decorating - viewtopic.php?f=6&t=47218&p=715743#p715743 Re: SOAKWELLS - How easy are they to put in and install ? 25Jul 30, 2010 11:30 am Garden - viewtopic.php?f=19&t=44214&p=670323#p670323 Decorating - viewtopic.php?f=6&t=47218&p=715743#p715743 Re: SOAKWELLS - How easy are they to put in and install ? 27Aug 01, 2010 10:56 pm Garden - viewtopic.php?f=19&t=44214&p=670323#p670323 Decorating - viewtopic.php?f=6&t=47218&p=715743#p715743 Re: SOAKWELLS - How easy are they to put in and install ? 29Aug 09, 2010 10:30 pm Garden - viewtopic.php?f=19&t=44214&p=670323#p670323 Decorating - viewtopic.php?f=6&t=47218&p=715743#p715743 Re: SOAKWELLS - How easy are they to put in and install ? 38Sep 25, 2010 8:04 pm bradtez After you have filled the bottom of the hole with blue metal, place your soakwell into the hole, assuming its a poly soakwell you will have it wrapped with geofabric textile. BEFORE you fill in the hole run your 90mm stormwater pipe into one side of your soakwell. Backfill the rest of your hole with bluemetal and soil over the top..Job done! You put the appropriate lid on than fill the hole up cause the soak well should still be atleast about 30cm below ground with lid on. Re: SOAKWELLS - How easy are they to put in and install ? 39Sep 25, 2010 8:24 pm duke bradtez After you have filled the bottom of the hole with blue metal, place your soakwell into the hole, assuming its a poly soakwell you will have it wrapped with geofabric textile. BEFORE you fill in the hole run your 90mm stormwater pipe into one side of your soakwell. Backfill the rest of your hole with bluemetal and soil over the top..Job done! You put the appropriate lid on than fill the hole up cause the soak well should still be atleast about 30cm below ground with lid on. You only need a lid if you are using the old concrete soakwell systems. With the new geo-composite systems they are built as a cube, so the lid is inbuilt so to speak. Build a garden your planet can be proud of www.bradsplanet.com.au Re: SOAKWELLS - How easy are they to put in and install ? 40Sep 25, 2010 9:28 pm Ahh understood. When you say put pipe into side, does it actually punch a hole into it assuming it is one of those box type ones or it just butt up against the side? DIY, Home Maintenance & Repair I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for… 3 41552 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8644 0 9825 |
