Browse Forums Building A New House Re: island bench powerpoints - photos please 7Sep 09, 2010 4:08 pm Build thread: viewtopic.php?f=31&t=32574 Re: island bench powerpoints - photos please 18Sep 25, 2010 2:43 pm For those of you with them on the end of the island - do you find they get bumped when there is something plugged in? It's too late for us, I guess, as I have ordered the kitchen with it in there, but I've been worrying a little that it isn't really a very safe position and won't get used as a result. Re: island bench powerpoints - photos please 19Sep 25, 2010 4:53 pm I've got mine at the end of the bench too. It will only be used for the ironing. In my case it won't get bumped since there is an ironing board beside it whenever something is plugged in. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: island bench powerpoints - photos please 20Sep 25, 2010 5:28 pm Nathan SteelFab Get them to cut some holes and chuck these in. I bought 3 of them for $125 each. The ones I have come with two plugs in each not the one in the photograph. That is so cool! www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6591 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11709 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31281 |
