Browse Forums Paving & Concreting Re: advise regarding providing concrete belt around house 3Sep 14, 2010 5:40 pm Hi James, The CSIRO BTF 18 http://www.publish.csiro.au/pid/3612.htm Foundation Maintenance and Footing Performance: A Homeowner's Guide Has a recommendation that to prevent variations in moisture content and the potential for cracking in a concrete footing/slab that a permimeter path be installed around the footing with a fall to prevent water from pooling around the slab and effecting the moisture content of the soil belwo the footing/slab. Which is where most of this discussion seems to centre around, as a preventative measure it may be appropriate but its going to vary in individual circumstances what is actually practical as well as how the individual footing design reacts to moisture variations and how tolerant it is of ground movement/moisture variation depending on the soil/clay/earth that its on. However also discussed is how important the placement of gardens, and plumbing locations can also be significant causes of moisture variation. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: advise regarding providing concrete belt around house 4Sep 19, 2010 10:54 am Edge 'beams' tend to retain the soil moisture content seasonally. This will reduce cracking, together with all the other things mentioned.(plumbing, falls etc) Where you are coming from is where you are going to... Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 9332 i would not be signing anything on the day read your contract about when builder submits final invoice generally, have to meet builder within 7 days of receiving final… 1 5346 Hi All, Recently we have signed a contract with Burbank and we are not aware that they have just DORSET, SURREY, HAMPSHIRE, KENT, PILBARA and REDGUM bricks from PGH are… 0 3905 |
