Browse Forums Owner Builder Forum Re: Rammed Earth Strawbale Walls 8Sep 09, 2010 11:45 am Thanks Thirsty Good luck with your journey into looking into this and thanks for your info. Cheers Arcadia, I thought it might have been a bit of overkill, and thanks for all the other info with the Double Glazing etc. Thanks Guys Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 14152 Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 5313 Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3627 |
