G'Day All.
I'm having trouble finding floating shelves with a depth of 300mm-400mm, deep enough to hold a Blu Ray player / Foxtel box ect.
Any ideas?
Thanks!
Browse Forums General Discussion 1 Apr 06, 2010 3:46 pm Re: Deep Floating Shelves 6Apr 06, 2010 7:10 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Deep Floating Shelves 12Sep 07, 2010 10:46 am Cheers. I ordered 3 of the media shelves from http://www.shelvingshop.com.au/ and I'm very happy with the finished product. Re: Deep Floating Shelves 13Sep 07, 2010 11:11 am Deep floating shelves are great to look at, but bear in mind that they do not reach their full load bearing capacity unless fitted into solid brick walls. Please ensure that you include at least 1 stud in your load bearing section. I know tht houses now-a-days are built with a stud spacing of 600 mm between centers. You would need to be careful about where you locate your screws. Suburbia is where the developer bulldozes out the trees, then names the streets after them. Re: Deep Floating Shelves 14Sep 07, 2010 11:18 am ![]() Deep floating shelves are great to look at, but bear in mind that they do not reach their full load bearing capacity unless fitted into solid brick walls. Please ensure that you include at least 1 stud in your load bearing section. I know tht houses now-a-days are built with a stud spacing of 600 mm between centers. You would need to be careful about where you locate your screws. You sure do... Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6750 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3447 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 1183 ![]() |
