Browse Forums Windows & Doors Re: -29 BAL Windows 8Aug 27, 2010 12:09 pm viewtopic.php?f=31&t=31037 harvard 27 DFH signed contract 16th March 2010 slab down 1st June 2010 frame started 8th June 2010 trusses and frame finished 24th June 2010 tiles almost done 14th July 2010 Bricks started 14th July 2010 Plaster started 28th July 2010 Paint 25th August 2010 Re: -29 BAL Windows 9Aug 27, 2010 3:26 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: -29 BAL Windows 10Aug 27, 2010 3:33 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: -29 BAL Windows 12Sep 06, 2010 11:03 am viewtopic.php?f=31&t=31037 harvard 27 DFH signed contract 16th March 2010 slab down 1st June 2010 frame started 8th June 2010 trusses and frame finished 24th June 2010 tiles almost done 14th July 2010 Bricks started 14th July 2010 Plaster started 28th July 2010 Paint 25th August 2010 Re: -29 BAL Windows 13Sep 06, 2010 2:08 pm Hi LJ - sounds concerning. I'm finding these BAL regulations a minefield and we're just in the quoting stage. Judging by the quotes we're receiving back from manufacturers there seems to be a lot of confusion. We've had quotes ranging from $20K to $100K. We have a lot of glass so the $20K quote was just wrong, all 3mm glass - I don't think they even looked at the fire regulation documents I sent along with the plans. Re: -29 BAL Windows 14Sep 06, 2010 3:02 pm j&r Hi LJ - sounds concerning. I'm finding these BAL regulations a minefield and we're just in the quoting stage. . I'm hearing you! And trying to get information today has just been a nightmare, everyone condradicts each other in their information. One says to me ******* aluminium mesh is fire safe- how that is possible I do not know, then someone else tells me no-it should be 2mm steel mesh like what Sooty May said. It's just nuts. Even ringing the actual building commision- the person there did not have a clue! Lisa- Finally in our house!!! Re: -29 BAL Windows 15Sep 09, 2010 1:45 pm To date I have found that all the major window manufacturers are very well aware of the BAL requirements (in Vic) & that basically if you supply a floor plan, site plan & BAL report they will quote / supply the correct configuration after consultation. The screens referred to are - 'a mesh with a maximum aperature of 2mm, made of corrosion - resistant steel or bronze.' Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: -29 BAL Windows 16Sep 09, 2010 1:48 pm . . . if anyone has further questions on BAL, I don't mind hijacking the topic. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: -29 BAL Windows 17Sep 09, 2010 11:39 pm me me pick me I have a question we are currently a bal 40 in victoria they are upgrading our windows to 6mm toughened glass and giving us flyscreens do they have to cover the entire window not just the openable portion and do you know if our front door is allowed to have glass panels any info would be much appreciated so I have my information correct when speaking with the ss thanks heaps Tammy viewtopic.php?f=31&t=31037 harvard 27 DFH signed contract 16th March 2010 slab down 1st June 2010 frame started 8th June 2010 trusses and frame finished 24th June 2010 tiles almost done 14th July 2010 Bricks started 14th July 2010 Plaster started 28th July 2010 Paint 25th August 2010 Re: -29 BAL Windows 18Sep 10, 2010 9:16 am Under the current legislation - which will undoubtably be revised in the next BCA - flyscreens to both fixed & openable. With doors - 6mm toughened glass & where the glazing is less than 400mm above ground level, decking etc screened. Doorframes to be metal. Weather strips or draught seals installed. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: -29 BAL Windows 19Sep 10, 2010 10:19 am ausdesign Under the current legislation - which will undoubtably be revised in the next BCA - flyscreens to both fixed & openable. With doors - 6mm toughened glass & where the glazing is less than 400mm above ground level, decking etc screened. Doorframes to be metal. Weather strips or draught seals installed. thanks ausdesign for your help will keep an eye on things viewtopic.php?f=31&t=31037 harvard 27 DFH signed contract 16th March 2010 slab down 1st June 2010 frame started 8th June 2010 trusses and frame finished 24th June 2010 tiles almost done 14th July 2010 Bricks started 14th July 2010 Plaster started 28th July 2010 Paint 25th August 2010 Re: -29 BAL Windows 20Sep 10, 2010 1:55 pm Hi Ausdesign - do you have any recommendations for Sydney manufacturers? I've sent off numerous plans to various places with very little response. We have a significant amount of glass (and now a window schedule) - as soon as they receive our plans I don't hear any more... 3 4203 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10543 |
