Browse Forums Building A New House Re: Our Green House 3Aug 26, 2010 9:54 am Building at Warner Lakes in sunny Queensland. Building with Bold Properties. Building thread is here! - https://forum.homeone.com.au/viewtopic.php?f=31&t=38957 Blog is here! - http://campoutforland.blogspot.com Re: Our Green House 10Sep 03, 2010 2:46 pm NO EXPECTATIONS, NO DISAPPOINTMENTS! Build Thread: viewtopic.php?f=31&t=27441 Landscaping Thread: viewtopic.php?f=19&t=43969 Re: Our Green House 15Sep 05, 2010 11:05 am Valid point free will (about demolition) but there are some serious issues with the house.... All the wiring and plumbing needs replacing... a lot of the rooms and windows face the wrong way... the rooms are all too small and the floors have warped due to water under the house... The floor, roof and walls are uninsulated and it has aluminum windows. We have also been told with the age of house there may be asbestos. So we would pretty much have to gut the house and remove the north and east walls... It is a good point, so I will have to look at demolition guys that recycle... Or if we ever get around to actually doing this we could give the bricks away... Re: Our Green House 16Sep 10, 2010 6:04 pm okay so have had a look for recycling demolition companies... Has anyone used Pace Demolitions? (http://www.pacedemolitions.com.au) They apparently sell the materials from demo's at their yard... That should make it a bit greeener... Re: Our Green House 17Oct 30, 2010 8:39 am We were looking at using Ecoblock for the build but not all builders will work with it. Instead it has been suggested to use Hebel blocks and render... So I was thinking that we could add a layer of foam and sarking insulation to the outside of the Hebel before the render to achieve the same benefits as Ecoblock... So I wanted to know if anyone as used Thermawall or Koolwall over hebel? of course there are legal avenues. You've already mentioned it. Sue them. I find it odd that lawyers wouldnt be willing to take on the case, given CCT evidence and… 1 23786 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 23922 |
