Browse Forums Building Standards; Getting It Right! 1 Aug 30, 2010 1:43 pm Hello, I have just moved into a new property and have a straight shower screen which is a frameless pivot hinge shower door with perimeter framed shower screen. There are very noticable gap's in between the two glass panels and the glass door (in the middle) and a lot of water is coming out of these gaps when the shower's on. Can anyone advise me what the acceptable building regulation is for gaps inbetween the glass door and panel either side of the door? Thanks Re: Standards for gaps between shower screen frames 2Aug 30, 2010 5:49 pm sheryl thompson Hello, I have just moved into a new property and have a straight shower screen which is a frameless pivot hinge shower door with perimeter framed shower screen. There are very noticable gap's in between the two glass panels and the glass door (in the middle) and a lot of water is coming out of these gaps when the shower's on. Can anyone advise me what the acceptable building regulation is for gaps inbetween the glass door and panel either side of the door? Thanks You will probably find there isn't one as things like shower screens are essentially cosmetic rather than functional. Ie the protection to your building structure is through the waterproofing not the shower screen. Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11189 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7490 |
