Browse Forums Bathrooms and Laundry Re: Tiled floor in shower - what is best way? 4Aug 31, 2010 8:33 am MumofTwo29 Whole floor is being tiled. We want the tiles running through into the shower, rather than a polymarble shower base. That's what I meant. Nice clean look (wall to wall tiles). Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Tiled floor in shower - what is best way? 5Sep 01, 2010 11:54 am If the tiler has done showers before and knows how to water proof than you should be fine ask for referals. Do you know the name of the shower kit he is using? Ask what warranty there is, tilers who build shower pans need to proove the experience in shower installations. You do not really need a second drain whole but it is recommended just in case you have a water leak issue from a vanity or something. If unsure about installing shower pans google it there is plenty of info on the net to look at even U tube. Craig Re: Tiled floor in shower - what is best way? 6Sep 01, 2010 1:32 pm Are shower pans concealed beneath the tiles or exposed. that is, when in the shower, do you stand on tiles? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Tiled floor in shower - what is best way? 7Sep 01, 2010 2:08 pm Casa2 Are shower pans concealed beneath the tiles or exposed. that is, when in the shower, do you stand on tiles? Shower pans is just a term tradies use as there are many components that make up a shower floor eg, cement bedding, water proofing membranes, cement motor and tiles it is not a pan they use underneath it is just a name they use to describe a shower floor. Yes there are shower pans you can buy fibreglass etc which they call shower pans. When we get called out to a shower job with tiles on them we still call them shower pans. If that makes sense. Craig Re: Tiled floor in shower - what is best way? 8Sep 01, 2010 7:20 pm Grout Perfect Casa2 Are shower pans concealed beneath the tiles or exposed. that is, when in the shower, do you stand on tiles? Shower pans is just a term tradies use as there are many components that make up a shower floor eg, cement bedding, water proofing membranes, cement motor and tiles it is not a pan they use underneath it is just a name they use to describe a shower floor. Yes there are shower pans you can buy fibreglass etc which they call shower pans. When we get called out to a shower job with tiles on them we still call them shower pans. If that makes sense. Craig Thanks. I understand. A shower pan is an area, not a method. Demolition August 2009, Construction Started September 2009, Completed December 2010 4 9080 I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 1703 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4944 |
