Browse Forums Owner Builder Forum 1 Aug 27, 2010 6:20 am Hi all
I'm building in southMorang and my land is ona very slight slope, the builder who I am going with is telling me that my slab is going to be higher than the front foot path but 10cm, Is this correct? or is it he does not want to dig down? I'm so puzzeled the last thing I want si to see a slab from the front of my house once finished Re: Slab higher than front footpath 2Aug 27, 2010 9:52 am You'll just have to build it up with soil. You don't want it the exact height as your footpath because then your driveway won't slope away. And it's probablybetter to have the house higher than the footpath rather than lower because if the house is lower you have to put in drains across the garage. One side of my house is lower then the road, and one is higher than the road due to the slope of the block. Hard to know without pics of your block, but I wouldn't be worrying. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Slab higher than front footpath 3Aug 27, 2010 5:48 pm Our block is flat and level and the top of our slab is currently around ~20cm above the footpath level. Once the landscaping and paving is complete it shouldn't be noticeable. Depending on the directional slope of your land 10cm doesn't seem like much of a difference. As long as it isn't going to affect your driveway approach angles I wouldn't worry about it. Re: Slab higher than front footpath 4Aug 27, 2010 7:35 pm I agree with all of the above I wouldnt worry about it personally, it has some good advantages Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46960 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20181 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 |
