Browse Forums Building A New House 1 Aug 26, 2010 10:08 am I have just chosen this brick for my house from a selection palette, but would love to know if anyone has used this on their house? http://www.southernbricks.com.au/bricks ... ation.html Would love to see this in the flesh, or at least photos if anyone has used it? Anyone? I noticed different pictures of these bricks look very different and I'm a bit worried now! What do people think? Building at Warner Lakes in sunny Queensland. Building with Bold Properties. Building thread is here! - https://forum.homeone.com.au/viewtopic.php?f=31&t=38957 Blog is here! - http://campoutforland.blogspot.com Re: Bricks - Anyone using Plantation Range - "Kumbia"? 2Aug 26, 2010 10:18 am Here are some images - apparently all of the same brick: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The first two look very different to the last... Building at Warner Lakes in sunny Queensland. Building with Bold Properties. Building thread is here! - https://forum.homeone.com.au/viewtopic.php?f=31&t=38957 Blog is here! - http://campoutforland.blogspot.com Re: Bricks - Two different pics, two different looking brick 3Aug 26, 2010 12:03 pm Different brick, the first two are tumbled (I think that's what it's called) and the last one is wire cut. I leave you to fend for yourself, figure things out yourself. Terrence Malick I might be misunderstanding.... but I would be more inclined to cut a section out from the cinder block wall and place the cistern in the cinder block wall. Very messy job… 1 1382 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5390 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6766 |
