Thanks, J
![Smile :)](./images/smilies/icon_smile.gif)
Browse Forums Paving & Concreting 1 Aug 13, 2010 4:55 pm Building in Darch 2010 (NOR PERTH) Land Titles Released 25/06/10 Land Settlement 14/07/10 Prestart Completed 17/08/10 Plans in Council 16/08/10 Building Licence Approved 22/09/10 Slab Poured 30/09/10 Bricking Started 14/10/10 Bricking Finished 26/10/10 Our Journey!! https://forum.homeone.com.au/viewtopic.php?f=31&t=36447 Our Blog Spot! http://joelnjayedarch.blogspot.com/ Re: Do we need a concrete pump? 3Aug 13, 2010 5:37 pm Where you are coming from is where you are going to... Re: Do we need a concrete pump? 4Aug 13, 2010 6:53 pm Building in Darch 2010 (NOR PERTH) Land Titles Released 25/06/10 Land Settlement 14/07/10 Prestart Completed 17/08/10 Plans in Council 16/08/10 Building Licence Approved 22/09/10 Slab Poured 30/09/10 Bricking Started 14/10/10 Bricking Finished 26/10/10 Our Journey!! https://forum.homeone.com.au/viewtopic.php?f=31&t=36447 Our Blog Spot! http://joelnjayedarch.blogspot.com/ Re: Do we need a concrete pump? 7Aug 13, 2010 8:44 pm Where you are coming from is where you are going to... Re: Do we need a concrete pump? 9Aug 15, 2010 8:55 am boom pump which is what you will have is app. for a 3 stage boom $700+plus, min. charge, app. $120 hr + after min. hr allowance in first charge app. $8 a cubic meter through the pump. The builder also has a margine on top generally 20% ++. slabs are impossible to pour with barrows If there is a hold up in aggitators then the pump guys still get paid by the hour hence the builders margin and base line profit for the builder. $1800 sounds pretty reasonable for a boom pump through a builder. If you were an owner builder then there would be no margin for a builder only pump charge. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Do we need a concrete pump? 10Aug 16, 2010 1:03 pm thanks, we are really young and inexperienced with this sort of thing, i have my dad in one ear saying "theres no way they need a pump for a corner block" but dad can be REALLY old fashioned about this sort of thing, so i guess the pump is needed and if its going to make the pouring easier then so be it! Really wish it wasnt sooo expensive! but hey one of the joys of building! Building in Darch 2010 (NOR PERTH) Land Titles Released 25/06/10 Land Settlement 14/07/10 Prestart Completed 17/08/10 Plans in Council 16/08/10 Building Licence Approved 22/09/10 Slab Poured 30/09/10 Bricking Started 14/10/10 Bricking Finished 26/10/10 Our Journey!! https://forum.homeone.com.au/viewtopic.php?f=31&t=36447 Our Blog Spot! http://joelnjayedarch.blogspot.com/ Re: Do we need a concrete pump? 11Aug 16, 2010 1:09 pm If i was to go through a builder i wouldnt expect the extra charge for the pump. Because I would assume this is required in all case and automatically forms part of the price. If a builder came back and asked for me to pay extra for steel i see this as the same thing as you cant get by without it. Re: Do we need a concrete pump? 12Aug 16, 2010 1:13 pm Pretty simple: 1) All slabs are done with a concrete pump. It's the most cost effective method. 2) Concrete pump is about $800 to $1k per a full day (you'll probably need if less than a day, so more like $600) 3) You shouldn't be charged any extra for a concrete pump since this is the way it's done (if it's a boom pump, as davinci suggests, then you should only pay the difference between a conventional and boom concrete pump, which I suspect is only about $400 per a day (guess only)) Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Do we need a concrete pump? 13Aug 16, 2010 1:36 pm the Wheelbarrow method in perspective. Question - What is the volume of your every-day "run of the mill" Wheellbarrow? Answer - approx 0.169 cubic metres (6 Cubic Feet) Question - How many Cubic Mtrs of concrete in a House Slab? Answer - Each pour is different but it would be safe to say somewhere around 27 - 30 cubic mtrs?? maybe more?? I'll let someone else work out the total number of wheelbarrows needed to move that volume of concrete. Re: Do we need a concrete pump? 14Aug 16, 2010 2:33 pm I would advise anyone to stay well clear of the site after rejecting the use of a concrete pump to pour a house slab ![]() Re: Do we need a concrete pump? 15Aug 16, 2010 3:23 pm good point bstar, maybe ask why it wasnt in the contract for reasons bstar pointed out Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Do we need a concrete pump? 16Aug 16, 2010 10:43 pm ![]() ![]() ![]() I have to laugh. Most of our slabs are poured by hand. ![]() Steer clear if you want but we have a fair bit more control and we can place it with an 80 slump mix. ![]() Most of a slab can be poured by the shute(s)Access to front and side permitted. >0.1 per barrow 10 points per cubic mtr average slab 20 cu mtrs 2 or 3 barrows for a large pour. (1 barrow every 60 sec x 3 ) X (20 cu mtrs = 200 points) (200 / 3 = 66.6 per barrow loads each) So in a couple of hours it could be possible to discharge 20 cu mtrs. Though the granos need to be able to keep up. It takes about 40 mins to screed 5 cu mtrs per grano and achieve a good compaction ratio. Just remember all the slabs that were poured prior to 'pumps' that didn't crack?? Sorry guys but I don't always buy it. Where you are coming from is where you are going to... Re: Do we need a concrete pump? 18Aug 17, 2010 9:44 am How much was footings? How much area? Where you are coming from is where you are going to... Re: Do we need a concrete pump? 19Aug 17, 2010 9:51 am last big pour i did was 1200 sq mtrs x 200mm thick, poured in a day, 240 qubic meters thats about 5 billion wheel barrows lol. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Do we need a concrete pump? 20Aug 17, 2010 9:57 am ![]() Yes well, I was refering to house slabs ![]() 1200 sq mtrs is a definate pump job. ![]() Where you are coming from is where you are going to... That's brilliant would appreciate if you have you can locate the other doc so I can use it with my discussion with the building surveyor 10 2516 |
