Browse Forums Heating, Cooling & Insulation Re: insulating double brick 2Aug 13, 2010 9:51 pm Where you are coming from is where you are going to... Re: insulating double brick 4Aug 13, 2010 10:59 pm Where you are coming from is where you are going to... Re: insulating double brick 5Aug 13, 2010 11:26 pm it has about 3 times more wall area than the floor also it only dbrick upto 2.1(eave height)above this which is in roof space is single brick, ceiling insulated with blow in celluose which is easy to improve but i think most of the problem is the walls Re: insulating double brick 7Aug 16, 2010 12:02 am I think insulation is the wrong solution. Need to find out how the moisture is getting there. If it is cold walls causing condensation more ventilation is required. Demolition August 2009, Construction Started September 2009, Completed December 2010 5 10757 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 12623 Just moved from a rental that was bearer and joist floor with double brick walls throughout. Worst house ever! Granted in Summer we didnt need any form of Air-Con to… 2 2228 |
