Browse Forums Home Finance Re: Land Equity 6Aug 10, 2010 9:28 am Titch101 Here's some background to clarify my situation - I purchased the block in June for $188000 (640sqm) and paid 10% deposit ($18800). Latest land release has blocks of 495sqm for $190000 so conservatively I would say I have about $10k so far in equity and I believe i will have at least $20k by the time titles are released. Titles will not be released til approx Mar 2011 at which time the balance will be due. Construction cost is estimated to be $200k and I am hoping to start building immediately on title release which I believe means that I would need my construction loan approved before the land is in my name. I don't think I will need to secure my loans until closer to title release (the closer the better as far as I am concerned), so early 2011 but am seeking clarification from the builder on this at the moment. I will have about $40k in savings to further contribute to both loans so will fall short of the 20% deposit needed for both land and construction loan, hence the question regarding whether I can use any equity in the block to make up the shortfall. Thank you for your responses and I hope that clears up my situation a bit better. Ok this is how it will likely work. Your lender may value the land higher than the purchase price as the time between purchase and settlement is around 12 months. There must be very good comparable sales, i.e. properties similar to yours that have sold for a higher figure. Note that some lenders use the lower of the valuation or purchase price, so see a broker and get them to help you apply with a lender that will use the valuation instead. Lenders have policies as to how long ago the contract needs to be signed before they will use the valuation only. Most need 12 months or more, some can accept as little as 3 months. So lets assume they value your land at $200,000. Here is how the figures would work: Land purchase price: $188,000 Land value: $200,000 Construction cost: $200,000 Estimate on completion value: $400,000 Total funds required: $388,000 Deposit paid: $18,800 Other savings: $40,000 Total contribution: $58,800 Loan Required (Shortfall): $329,200 Loan to Value Ratio: 82.30% Estimate LMI: $1,741 to $3,014 depending on the lender you use. I would recommend that you consider the following options: * Try to come up with a little more money. If you can reduce the loan to just $320,000 then you can avoid LMI entirely. * The valuation is critical in your situation! I would strongly recommend that you go with a lender that allows you to order the valuation up front, even if it costs you a small fee. You can then choose the lender that gives you the best valuation on the land. A mortgage broker can help you with this. * Talk to the selling agent around the time the valuation is being done and ask him to help you come up with a list of recent comparable sales, provide this to the valuer to make sure he doesn't just come back at the purchase price. * If you are going to end up paying LMI it pays to shop around. Again a mortgage broker can quickly let you know which lenders will have the cheapest LMI for your situation. as you can see in the above figures there are quite large variations. Note that lenders that use Genworth Financial for their LMI may charge you extra LMI on the construction portion if you do not apply for the construction loan at the same time as the land loan. This is because it would be considered to be a loan increase which is charged a higher premium rate. Good luck, hope that helps! Let me know if I have misinterpreted any of your figures. The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19880 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6791 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25382 |
