Browse Forums Home Theatre & Automation Re: connecting ceiling speakers to Samsung HT-C5500 3Aug 09, 2010 8:29 pm photos of said units type sof cables you have involved.... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: connecting ceiling speakers to Samsung HT-C5500 4Aug 10, 2010 10:25 am Kin, do you mean you want to run 2 pairs of In-ceiling speakers AS WELL AS the 6 speakers (5 speakers + passive subwoofer) it is already running? Or are you thinking of replacing 4 of the existing speakers (the front pair and the surround pair) with the In-ceilings? Re: connecting ceiling speakers to Samsung HT-C5500 5Aug 10, 2010 1:39 pm Thanks for your replies. I have found out the below picture that can help you to understand what I meant. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ In the above picture, you can see that the terminal from the product for the speakers cannot be inserted by the normal speaker cables. My question is: how can we plug the speaker cables (from my ceiling speakers) into the product (Samsung HT-C5500)? Hope you understand my questions. Thanks. Cheers, Kin Metricon Amira Re: connecting ceiling speakers to Samsung HT-C5500 6Aug 10, 2010 5:12 pm I'm going to assume your answer to my question above is that you are going to replace the existing Samsung speakers with your In-ceiling ones. Speaker wire is speaker wire - it must have 2 conductors (+ & -). Most use a 'side-by-side' or 'figure 8' type speaker cable but some (eg. Bose) use coaxial wire, but it still has 2 conductors. You simply cut the existing Samsung wire (that came with the system) somewhere and splice/join on some standard speaker wire to run up to the In-ceiling speakers. P.S. I saw the above picture in the PDF manual I downloaded before I replied earlier... Re: connecting ceiling speakers to Samsung HT-C5500 7Aug 10, 2010 8:00 pm Rodda I'm going to assume your answer to my question above is that you are going to replace the existing Samsung speakers with your In-ceiling ones. Speaker wire is speaker wire - it must have 2 conductors (+ & -). Most use a 'side-by-side' or 'figure 8' type speaker cable but some (eg. Bose) use coaxial wire, but it still has 2 conductors. You simply cut the existing Samsung wire (that came with the system) somewhere and splice/join on some standard speaker wire to run up to the In-ceiling speakers. P.S. I saw the above picture in the PDF manual I downloaded before I replied earlier... Thanks so much, Rod!! That's what I was asking about. Besides cutting the Samsung wires, are they any other ways to connect ceiling speaker cable to Samsung HT-C5500. Thanks. Cheers, Kin Metricon Amira Re: connecting ceiling speakers to Samsung HT-C5500 8Aug 11, 2010 9:03 am do you curreently have speaker cable in the wall?? if so just get a wall plate with banana or binding posts connect the cable there and then just "adapt" the out puts of the Amp to that.. be the way I would do it... of course I have all the right tools/ specific experience to do this ... might be hard for a newbie... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: connecting ceiling speakers to Samsung HT-C5500 9Aug 11, 2010 1:10 pm Thank you so much for your advice. Just wondering if I can use something like the below picture (Speaker Selector)? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ By the way, 4 ceiling speakers have been fitted on the ceiling and 4 pairs of speaker cables have been pulled out from the wall... HT-C5500 <---> Speaker Selector <---> Speaker cables, does it work? Thank you. Cheers, Kin Metricon Amira Re: connecting ceiling speakers to Samsung HT-C5500 10Aug 11, 2010 3:42 pm don't see why not... if you want to go down that path.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: connecting ceiling speakers to Samsung HT-C5500 13Dec 11, 2012 8:55 pm Hi Sangeeta, Does teh TV have speaker outputs on it? "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 23886 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 |
