Browse Forums Kitchen Corner Re: IKEA kitchen - what do you think? 8Jul 31, 2010 10:34 pm NO EXPECTATIONS, NO DISAPPOINTMENTS! Build Thread: viewtopic.php?f=31&t=27441 Landscaping Thread: viewtopic.php?f=19&t=43969 Re: IKEA kitchen - what do you think? 14Aug 06, 2010 8:12 pm pobjoy1 WOW! boiselfish, I wholeheartedly agree with Elizabeth: that is truly magnificent. boiselfish, How did you get the L-shaped kitchen to fit perfectly across the far wall (beneath window)??? That is a miracle in itself. We have a huge combined living / kitchen / dining area, so not concerned with the L-shaped kitchen actually fitting snugly across the breadth of a room. However, we have a 90cm oven and cooktop, and IKEA don't have cabinets big enough to accommodate 90cm appliances. Do you think that a gifted installer could get past those problems too? ANDY / JESS Well... If you look closely next to the oven (you probably cant see it only I know its there), the installers put a small piece of white melamine from some other part of the pack to make it look like it fit snugly. I think it was out by about 7 cm so that was their solution. SO look at the picture and you can se I purchased the oven/hot plate unit, a draw unit, a 60 cm unit for the sink, one corner unit and then another 2 45 cm units(I think) where were made into one to accommodate the hot water service under the bench. As for the bench top I cant remember the lengths it came in but im sure it was over 2m so it was just cut to size to fit correctly. As for the 90 cm appliances you have you could consider 2 of the 60 cm oven sections and cut them to size (taking 15 cm off both thus creating a 90 cm oven section). The installer should be able to overcome most of your problems I would suggest going to Ikea and getting them to provide you with installer details. They will be very experienced in their range of things and may have better suggestions for you. Helpful? Hope so! NO EXPECTATIONS, NO DISAPPOINTMENTS! Build Thread: viewtopic.php?f=31&t=27441 Landscaping Thread: viewtopic.php?f=19&t=43969 Re: IKEA kitchen - what do you think? 15Aug 12, 2010 8:10 pm Pobjoy We were planning an Ikea kitchen, and the Ikea kitchen planning person I talked with said a lot of people just buy a couple of panels and get a cabinet maker to knock together a 900mm oven cabinet. Of course, the trick is to find someone who's happy to just do the one part of a kitchen! (We've since found a kitchen mob here in Melbourne who will do us a E0 (no vocs) kitchen for not a heap more than we would have paid with Ikea. Hooray, now I just have to find an E0 laminate or veneer I can live with. ) e. Re: IKEA kitchen - what do you think? 16Oct 13, 2010 12:34 pm Hi Andy & Jess, (Pobjoy1) I'm having trouble contacting you and wonder if you're still happy to share the tradies you've used in the Geelong area... We'd love to hear from you. You can contact me direct: via pm (edited by mod to remove private contact details) No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6636 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39768 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8424 |
