Browse Forums Eco Living Re: Heat loss through window problems 2Aug 06, 2010 4:28 pm These days most of the heat transfer is through the frame as double glazed windows should be sufficient to prevent too much transfer. Your best bet is PVC or thermally broken aluminium frames. Eco Classic is a good place to start looking into PVC and Creative Windows are currently supplying thermal break windows. the big companies such as A&L Windows and Dowell windows are not too far away (6 months maybe) from having thermal break product though "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay Re: Heat loss through window problems 3Aug 06, 2010 4:50 pm kid81 These days most of the heat transfer is through the frame as double glazed windows should be sufficient to prevent too much transfer. Your best bet is PVC or thermally broken aluminium frames. Eco Classic is a good place to start looking into PVC and Creative Windows are currently supplying thermal break windows. the big companies such as A&L Windows and Dowell windows are not too far away (6 months maybe) from having thermal break product though Thanks kid81, we supply PVC, aluminium and thermally broken aluminium. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Heat loss through window problems 4Aug 06, 2010 9:55 pm Double glazing will cut down on direct solar gains compared to single glazing - perhaps up to 10%. However it will cut down conduction / convection heat losses by 33 to 50%. Therefore a net gain in winter and even better in summer to prevent heat gain. Heavy curtains with pelmets are a good additional heat flow retarder. Don't like pelmets - if you only have 2.4 metre ceilings could consider floor to ceiling curtains - the pelmet then is not so prominent incorporated into the cornice line. Otherwise I have heard suggestions of cellular blinds being good or else lined roman blinds where the top of the blind is flush against the wall and also the sides of the blind when down. (Care needs to be taken not to block winter solar heat gains with the blinds.) Must keep sun off glass in summer - eaves or other shading structure to North. References: Sustainability Vic http://www.sustainability.vic.gov.au/re ... ection.pdf Your Home Tech Manual http://www.yourhome.gov.au/technical/fs410.html WERS Site http://www.wers.net/how-wers-works/selectingwindows Re: Heat loss through window problems 5Jan 27, 2011 10:30 am Stay away from A&L I'm yet to explore there quality of product I have waited over 3 months to have my double glazed argon filled bi-fold installed and windows delivered. They seem to take your money but offer no customer support. Re: Heat loss through window problems 6Apr 18, 2011 10:26 pm keilor_ob Stay away from A&L I'm yet to explore there quality of product I have waited over 3 months to have my double glazed argon filled bi-fold installed and windows delivered. They seem to take your money but offer no customer support. Did you get your windows? Re: Heat loss through window problems 8Jun 12, 2011 8:00 pm Have you considered cellular/honeycomb blinds? Re: Heat loss through window problems 9Oct 19, 2011 9:10 pm I have recently been to the Dowell factory in Bayswater where they have released the ThermLine range in both awning and sliding window formats. I met the designer and not only does the new profile look great but WERS have rated them as the best on the market. GJ Gardner are researching them very closely for some of their more upmarket homes in Mebourne Eastern suburbs. Re: Heat loss through window problems 10Oct 26, 2011 1:51 pm Local hardwood timber frames on double glazed windows provide no thermal bridging issues and are a far more environmentally sensitive choice compared to the all other options (such as PVC and Al), this is about sustainable building after all.....As Eccles rightly pointed out, it is most important to get your eve/solar pergoal design right to allow full solar access in winter and full shading in summer. Also allow for plenty of cross flow ventilation options in summer too. Steve There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2978 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7320 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38444 |
