Browse Forums DIY, Home Maintenance & Repair Re: How can you tell if your roof still leaks? 2Aug 01, 2010 3:16 pm sisu Hi all, My roof leaked a while ago and a small mound was forming on my ceiling. Then the drought came and all was well until it rained again. I touched the ceiling to see if it felt damp and poked my finger through it. I got a roof tiler in to fix one part of the ridge capping. I haven't fixed the ceiling as yet and want to know if I can test the roof first. How would you do this? Do I have to sit in the roof next time it rains? Try running the hose onto the roof and let the water run over the tiles. Then get up into the roof while the hose is running to check for leaks. Not the most water wise way... but it should work Re: How can you tell if your roof still leaks? 3Aug 01, 2010 6:00 pm Another way (you may have to a contortionist to do it though) is to get in the roof and see if any light is coming in. Not entirely foolproof but its a good start. Or you could borrow one of these from the local airport... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://fire-engine-photos.com.s3.amazonaws.com/19651.jpg Re: How can you tell if your roof still leaks? 4Aug 02, 2010 1:52 pm I've been in the roof with a good torch when it leaked in the past during a short rainy period (I wanted to know where the water was coming in), but couldn't tell so the tiler had to guess it was the ridge capping on that section of the house. I know a friend got her roof fixed only to divert the leak to another area of her ceiling. There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2456 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 18582 2 10990 |
