Browse Forums Home Theatre & Automation Re: Mounting a small LCD tv on wall with no stud 2Apr 10, 2008 3:08 pm In short if you like your tv then NO!!!
You need a stud and there are lots of different ways to acheive this but I would suggest this: The bracket mounts to the wall on the stud and the Tv remains in the alloted position using the offset of the bracket.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ or this depending on how far away from the stud you are... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Use no stud at your peril ![]() ![]() ![]() Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 2575 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 7696 Thankyou for your advice. We do have Caesar coming out and hopefully resolve the issue for us. 4 20180 |
