Browse Forums Building A New House Re: Who's building with M3tr!con in Sydney ? 43Jun 15, 2010 12:58 pm http://dreamzattheponds.blogspot.com To be invited to our blog send a PM with your email. Settled on land 25th June Exchanged contracts on Land April 14th 2010 Building our First Home Re: Who's building with M3tr!con in Sydney ? 45Jun 15, 2010 1:25 pm http://dreamzattheponds.blogspot.com To be invited to our blog send a PM with your email. Settled on land 25th June Exchanged contracts on Land April 14th 2010 Building our First Home Re: Who's building with M3tr!con in Sydney ? 49Jul 26, 2010 11:18 pm Hi Tempura, I had a similar plan to yours regarding the zones. However after talking to an air-conditioning installer I am having second a thought about it. Apparently the indoor unit in a ducted system runs at constant speed. So switching off zones only causes the airflow to increase in the remaining zones, which is noisier but may not really be much cheaper to run. The only system that has a variable speed indoor unit is made by Actron. I haven't investigated much this theory. It may be worthwhile to ask the question in the cooling/heating forum... DKP Re: Who's building with M3tr!con in Sydney ? 51Jul 27, 2010 5:59 pm tempura DKP, so how do you design your ducted air con in your home now? perhaps it will give me an idea. Hi Tempura, We are building the Laguna. Earlier we had the idea of closing off the open-plan living space at the rear of the house from the front with door, and create a dedicated zone for that. We were also thinking of creating a zone for each bedroom upstairs. The idea was to reduce running cost. However... Three bedrooms will be used with the 4th ones being a guest room. So there isn't much of a need for zoning each individual bedroom. Considering the potential airflow/noise issue the plan now is to have the whole upper floor as a single zone. As for the ground floor isolating the rear of the house does not make much sense because the front is where the staircase is and that area would always be conditioned anyway because it forms part of the airflow path going back to the return grille upstairs. So I guess the standard 2-zones system is the way to go then. The only limitation is that both floors cannot be conditioned simultaneously, which I think is not really an issue. I am not expert on the subject though so you might want to consult some air-conditioning specialist... DKP Re: Who's building with M3tr!con in Sydney ? 52Jul 29, 2010 10:26 am Thanks DKP. much appreciated. Anyone has the fine print of M "Guaranteed 18 weeks build period"? I just would like to understand the terms and conditions for it, to get $300 per week, in case it exceed that time frame. I heard that we must fight HARD for it I don't want this to happen, but i need to look at the worst case scenario if it does happen. just to prepare myself. and with regards to 150 days after 1st deposit ($1000) put in ... if passes 150 days and the fault is with us (delay in land registration ... which i can't see why this is our fault, but o well what can we do), we need to pay M 0.5% of the total house price (e.g. $300,000), which is $1,500. Let's say next month after that, it is still not registered, do we pay 0.5% of $300,000, or $301,500? And what will the turning point (end of us paying that 0.5% per month)? e.g. is it the day when we see that there's M3tr1c0n truck/builder in front of the lot? My apology for my lack of knowledge. Re: Who's building with M3tr!con in Sydney ? 53Jul 29, 2010 4:03 pm Tempura, the 0.5% is based on your final contract price. You will no longer be required to pay the 0.5% once you are ready (i.e. you have your DA approval and construction certificate). So basically once everything is in place for M to start building. You actually pay the 0.5% AFTER handover too... so you won't actually need to pay it before then. It will just be raised as a variation and you have to pay it after. Re: Who's building with M3tr!con in Sydney ? 57Apr 28, 2011 2:36 pm ours is still in the council process and to be honest havent been all that impressed with m! Land registers in a couple of weeks. See blog http://penbeandstefan.blogspot.com/ Will be going to see m shortly to sort some things out with have been abit of a concern. I wont go into details. Re: Who's building with M3tr!con in Sydney ? 58Sep 08, 2011 11:29 am we are now at construction phase!! =) http://penbeandstefan.blogspot.com/ How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6037 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 81826 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
