![Shock :::](./images/smilies/Shok.png)
Any idea from your builder when you might see a start?
Browse Forums Building A New House Re: SANDARRA GENERAL DISCUSSIONS 461Jul 16, 2010 7:20 pm Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: SANDARRA GENERAL DISCUSSIONS 463Jul 17, 2010 9:28 am Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: SANDARRA GENERAL DISCUSSIONS 464Jul 17, 2010 1:38 pm Land: Stage 4 Title Settlement: 22nd April '10 Building: DFH, Hartley Site Start: (Scrape) 3.7.10 Slab Completed: 17.7.10 Frame Completed: 30.7.10 Gutters & Fascia Completed: 3.8.10 Roof Completed:9.8.10 Electrical & Plumbing Completed: 13.8.10 Bricks Completed: 24.8.10 Lock up Stage: 30.8.10 Re: SANDARRA GENERAL DISCUSSIONS 465Jul 17, 2010 4:47 pm Building with the Big M, Sandarra Settlement July 16 Site Scrape Sep 22 Slab Oct 12 Framing commenced Oct 13 Build thread: viewtopic.php?f=31&t=39517 Re: SANDARRA GENERAL DISCUSSIONS 468Jul 18, 2010 11:04 am Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: SANDARRA GENERAL DISCUSSIONS 469Jul 18, 2010 2:36 pm Land: Stage 4 Title Settlement: 22nd April '10 Building: DFH, Hartley Site Start: (Scrape) 3.7.10 Slab Completed: 17.7.10 Frame Completed: 30.7.10 Gutters & Fascia Completed: 3.8.10 Roof Completed:9.8.10 Electrical & Plumbing Completed: 13.8.10 Bricks Completed: 24.8.10 Lock up Stage: 30.8.10 Re: SANDARRA GENERAL DISCUSSIONS 470Jul 18, 2010 3:24 pm ![]() ![]() Hi guys, We r stage 6ers. Today we measured our land and it came over 1mtr short in width. As we have not titled yet, should we be concern or should we be notifying Maddox regarding this, or are we just worrying too much? 1 meter is a fair amount katie, I hate to say it but you're sure you have the right lot and you measured it in a single length with long tape measure, there couldn't be an issue in your maths? Don't mean to imply your incorrect or anything, but have you double checked it to be sure? What pegs to you check against? The actual title pegs are buried to surface level and then marked with thinner peg sticks with white tops. These only just went in before we settled, so you may want to check your measuring to the right pegs, as there are also others for the services etc that are only differentiated by the numbers or ties on them. This is something that i'd consider fairly critical given the cost of the land, as well as the lot area governs all the related costs of rates, land tax payable at settlement etc. But yes, if in doubt definitely contact Maddocks or your conveyencer to do it on your behalf, ask for a copy of the stage plan of subdivision as this will show the exact dimensions of your lot and identify it by lot number. I'd go make sure you can find the pegs assuming they are in and measure it against the plan of subdivision. For reference we measured ours and it was accurate to within 1-2cm which is as accurate as the cheap tape i bought from bunnings can be considered reliable to. Hi Belial, We've definetly got the lot correct, double checked and triple checked. We measured the land with a 3mtr tape measure (unfortunately that was all we had), but there shouldn't be that much of a decreptancy right? I'm hoping that we may have measured the wrong pegs. Mite go down to bunnings to buy a longer tape measure & put on the gum boots and r-measure. Thanks Belial Re: SANDARRA GENERAL DISCUSSIONS 471Jul 18, 2010 3:36 pm ![]() Hi Belial, We've definetly got the lot correct, double checked and triple checked. We measured the land with a 3mtr tape measure (unfortunately that was all we had), but there shouldn't be that much of a decreptancy right? I'm hoping that we may have measured the wrong pegs. Mite go down to bunnings to buy a longer tape measure & put on the gum boots and r-measure. Thanks Belial No worries, just come back from down there, rain isn't too heavy but the wind chill is pretty darn cold. So rug up if you do go down ![]() Using a 3m tape your still looking at 4, or 5 sections so depending on how accurate you were, i'd say you'd easily get up to about 20-30cm of variation depending on how specific you were being with placing it but 1m is well and truly excessive. Check the pegs, check the plans, if you don't already have the POS, you might have been sent an update from it which shows your crossover and services location, otherwise you can go back to the original POS in your contract which should show all the correct lengths, as well as give you a reference in relation to the kerb of where you should expect to see the pegs. Our tape we got done there was blue plastic body with a 50m white fibreglass tape on the spool, in a no name brand was about $25-30 if i recall correctly. Not a huge outlay compared to the brand names at $60+ and reusable for measuring slabs etc when the time comes. I think they may also have had some cheaper at about 25m long, as one of our sides is over 30 it was just as easy to get one that could do the lot. Hopefully it was just a incorrect peg, let us know how you got on. ![]() Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: SANDARRA GENERAL DISCUSSIONS 472Jul 21, 2010 12:19 pm Re-measured our lot yesterday and the results are in.. and with the correct tools (thanks Belial for measuring tape advice) it measured up correctly this time =D Also update for Stage 6ers, we were advised by our conveyancer that the POS has been lodged. Fingers crossed it gets approved in the first go. Re: SANDARRA GENERAL DISCUSSIONS 473Jul 21, 2010 12:23 pm Good Luck Katie, You would hope that after lodging 5 previous stages that it should get approved first time and quickly... (in theory anyway) But having said that stage 5 was submitted 3 very frustrating times before we got approval. Hopefully you stage 6-ers won't have that issue. Site Start - 20th July 2010 Slab Pour - 30th July 2010 Frame Start - 6th August 2010 Roof Tiles - 18th August 2010 Plaster Completed - 6th September 2010 Bricks - 3rd - 20th September 2010 Painting - 4th October 2010 Fitoff Begins - 21st October 2010 Re: SANDARRA GENERAL DISCUSSIONS 474Jul 21, 2010 12:36 pm ![]() Good Luck Katie, You would hope that after lodging 5 previous stages that it should get approved first time and quickly... (in theory anyway) But having said that stage 5 was submitted 3 very frustrating times before we got approval. Hopefully you stage 6-ers won't have that issue. Sixth time is the charm isn't it? ![]() Also good to hear Katie that it all measures up correctly. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: SANDARRA GENERAL DISCUSSIONS 475Jul 21, 2010 6:24 pm ![]() ![]() Good Luck Katie, You would hope that after lodging 5 previous stages that it should get approved first time and quickly... (in theory anyway) But having said that stage 5 was submitted 3 very frustrating times before we got approval. Hopefully you stage 6-ers won't have that issue. Sixth time is the charm isn't it? ![]() Also good to hear Katie that it all measures up correctly. Thanks guys but I'm gonna have to take a raincheck on that.. ![]() ![]() ![]() Re: SANDARRA GENERAL DISCUSSIONS 476Jul 27, 2010 7:19 pm Hey guys windows got put in today and noticed one of them was shattered ![]() Land: Stage 4 Title Settlement: 22nd April '10 Building: DFH, Hartley Site Start: (Scrape) 3.7.10 Slab Completed: 17.7.10 Frame Completed: 30.7.10 Gutters & Fascia Completed: 3.8.10 Roof Completed:9.8.10 Electrical & Plumbing Completed: 13.8.10 Bricks Completed: 24.8.10 Lock up Stage: 30.8.10 Re: SANDARRA GENERAL DISCUSSIONS 477Jul 27, 2010 7:29 pm ![]() Hey guys windows got put in today and noticed one of them was shattered ![]() Seems to be symptomatic of the "not my problem" mentality that seems to be quite pervasive at the moment. That said its probably cheaper for the builder to have a glazier come out to replace a single pane than order a full replacement window. However on the upside your garage frame looks good. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: SANDARRA GENERAL DISCUSSIONS 478Jul 28, 2010 3:14 pm Hey all just wanted to say hi to our future neighbours at Sandarra. My wife and I will be building our new house in Malua circuit soon hopefully and I just had a question for anyone that might be able to help me. Our builder tells me that we can save money on temp fencing costs if we construct a fence before building comences and I have quotes from people that can do it but was wondering if I had to contact my (direct) nieghbours first? Is it the norm to split the bill / get it approved? and if so how do I get in contact with them? Cheers Danny Sandarra Stage 11 Building Dennis Family Homes, Lancaster Re: SANDARRA GENERAL DISCUSSIONS 479Jul 28, 2010 6:33 pm welcome ! If you contact club links they will give you the contact details of your neighbours. I think you just requested to join our facebook group and there is more info there Land: Titles 27/10/2009 - settled 9/11/2009 House Design: Talbot 28 (Contemporary Façade) Estimated move in date April 2010 ... ok maybe June 2010 with any luck Site Start 22/01/10 - 20/08/10 Handover!! Sandarra Facebook Group Re: SANDARRA GENERAL DISCUSSIONS 480Jul 28, 2010 9:40 pm ![]() Hey all just wanted to say hi to our future neighbours at Sandarra. My wife and I will be building our new house in Malua circuit soon hopefully and I just had a question for anyone that might be able to help me. Our builder tells me that we can save money on temp fencing costs if we construct a fence before building comences and I have quotes from people that can do it but was wondering if I had to contact my (direct) nieghbours first? Is it the norm to split the bill / get it approved? and if so how do I get in contact with them? Cheers Danny Hey Dan, welcome to the forum and neighbourhood, we are also building with DFH, Hartley! how has everything been so far with them?? We were also told that we could save money on having our fences put up instead of temp fencing. Unfortunatly we ended up going with temp fences as we didn't want to take the risk of having the tradies damage the real fence as there is only little space as it is between the home and the fence which means the brickes need to have access to lay bricks, especially if your garage sits on the boundry of your lot. So what they do is they would have to pull down the fence and work around it while the fence gets damaged. Good luck with your build!! Land: Stage 4 Title Settlement: 22nd April '10 Building: DFH, Hartley Site Start: (Scrape) 3.7.10 Slab Completed: 17.7.10 Frame Completed: 30.7.10 Gutters & Fascia Completed: 3.8.10 Roof Completed:9.8.10 Electrical & Plumbing Completed: 13.8.10 Bricks Completed: 24.8.10 Lock up Stage: 30.8.10 You should check your detail drawings, it may show downpipe within brick pier. 14 14927 ![]() |
