Browse Forums Kitchen Corner 1 Jul 16, 2010 10:51 pm Building the Pegasus New Generation Bletchley Pk, Southern River Land purchased 03/2009 Contract 06/2009 Prestart 09/2009 Land cleared/sand Pad 10-12-09 Fittings done 17-12-09 SLAB!! 18-12-09 Brickies started 27-1-10 Roof Started 2-3-10 Lock Up 13-5-10 Re: installing diswasher 2Jul 16, 2010 10:58 pm Building with Life$tyle Homes in Perth SOR Key Dates on First Page of my Thread viewtopic.php?f=31&t=38761 Re: installing diswasher 3Jul 17, 2010 6:39 am It's not the hardest job in fitting a kitchen, but you might need some specialist tools and materials - simple answer is that if you need to ask this question you are probably better off getting someone else to do it - it never really costs "that" much and you will know that it's been done (hopefully) properly. Doesn't have to be a plumber unless extra water fittings need to be installed but they are the people I would go to for this job. Cheers, Earl Re: installing diswasher 4Jul 18, 2010 4:51 am ladsos how hard is it or do we need a plumber? Do you already have a tap and a drain point for it? If so then you can do it yourself by connecting up the water tap, these days just cold and connecting the drain, usually to a point on the S trap under the sink. If you don't have these connections you will need a plumber to install. It shouldn't be too hard provided your existing kitchen taps come from underneath the sink. If they come from the wall above then that is a major job. Re: installing diswasher 5Jul 18, 2010 11:00 am thanks, husb recons he can do it! Building the Pegasus New Generation Bletchley Pk, Southern River Land purchased 03/2009 Contract 06/2009 Prestart 09/2009 Land cleared/sand Pad 10-12-09 Fittings done 17-12-09 SLAB!! 18-12-09 Brickies started 27-1-10 Roof Started 2-3-10 Lock Up 13-5-10 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6745 Ask yourself if the insurance company will be aware of the Reno. 4 7461 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8488 |
