Browse Forums Building Standards; Getting It Right! Re: neighbour gutter on my property 12Jul 02, 2010 4:43 pm there's actually legislation somewhere (i can't remember where - possibly in the Property Law Act 1958) that basically ignores encroaches onto neighbour's land by less than a certain amount. I think it's 30cm, but it may be 50cm. If it's less than that, you'll find there's actually nothing you can really do. Re: neighbour gutter on my property 13Apr 28, 2013 11:49 am Hi d3p What was the resolution if you don't mind me asking? I'm in the final stage and have a similar issue. We have had the land resurveyed and the the neighbors gutter is indeed over on our side (zero boundary). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We can't complete our box guttering as per plan. The builder is onto it. I'm just curious as to your outcome... Thanks Re: neighbour gutter on my property 14Apr 28, 2013 12:24 pm Hi, I am no builder however I am having two boundary walls in my new house build. I was told specifically by my builder that boundary walls are more expensive as the gutter has to be internalised at the boundary to contain water. Looks like a big box that ends dead in line with the brickwork that should butt up against the boundary. If it is hanging over your side then your neighbour would have to retrofit the correct guttering. By the look of the pic there is not the option to take care of it on your side as the gutter seems to encroaching your brickwork. I would recommend your building company provide you with a letter to take to the council and to your neighbour. It would probably require a new site survey to confirm that your building is where it should be and the boundary line has been correctly marked. Councils will ask for the site surveys and there will be the one you are building off and the one your neighbour built off, both will claim to be correct, hence a third, independent survey to confirm will be needed. Then take it from there. Very surprised that it was not mentioned that the guttering was not the correct guttering for a boundary wall. Good luck. Mark Re: neighbour gutter on my property 15May 01, 2013 9:59 pm That just looks ridiculous! Best thing for you is to pay for a site survey and see exactly who has built out of there building envelope! No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4942 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8996 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2551 |
