Browse Forums Building A New House Re: PIMP my plans ..please?! 2Jun 25, 2010 10:46 am Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: PIMP my plans ..please?! 4Jun 25, 2010 2:45 pm A couple of things which occur to me - I am pointing them out but have no suggestions on how to address them - if indeed, you feel they need addressing 1. the entry is a bit tucked away and obscure from the street front. 2. one of the bathrooms has a window opening onto the front porch by the front door, not sure if that is a good idea. 3. the kitchen seems a bit exposed to the entry area - this could be addressed by swapping the kitchen with part of the dining/family area - may mean more plumbing cost though as wet areas are then not all aligned as they are now. 4. access to the main bedroom is a bit awkard, tucked around the corner of the liveing area and directly near the dineing table, could get a bit noisy for the bedroom occupants if others are still chatting around the table. 5. Laundry is that little area next to the garage? Seems a small laundry for a such a large family home and has no direct light/ventilation/outside access - that could be a problem IMO. Re: PIMP my plans ..please?! 5Jun 25, 2010 2:57 pm Hey Kiwi - I like it alot. I love how you have all these different spaces that seem to work really well with each other. The only things I did pick up that you might want to consider is located in the entry - if you are standing at the front door you will be able to see directly into the kitchen. II you put a little reccess where the angled wall is you might be able to block the view to the kithcen and make the space a bit more interesting as well as giving some privacy. Also - maybe you can make the window in the bathroom a high light window and make it the length of the bathroom to give the same light but also some privacy. THE LIGHT OF MY LIFE IS 495 SQM OF BEACH SAND AND WEEDS! http://missvintageshouseofpain.blogspot.com/ Re: PIMP my plans ..please?! 6Jun 25, 2010 3:32 pm I like it-Helyn does raise a couple of good points but at this juncture I haven't got any suggestions as to how to address them either! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: PIMP my plans ..please?! 7Jun 26, 2010 2:05 pm 1. the entry is a bit tucked away and obscure from the street front. I know, it is a bit gros ay. I had thought of a portico, but we are so tight with $$$$ that doing one might be too expensive. I am going to have the nicest path to my fancy pivot door though to make up for it and as we are in the country no one will see it anyway! 2. one of the bathrooms has a window opening onto the front porch by the front door, not sure if that is a good idea. It isnt...maybe a high up one like Miss V mentioned might work better. 3. the kitchen seems a bit exposed to the entry area - this could be addressed by swapping the kitchen with part of the dining/family area - may mean more plumbing cost though as wet areas are then not all aligned as they are now. I NEVER wanted a kitchen to be seen from the front door..all the plans I have done in the last 2 years havent had the kitchen in full view. I have put the fridge in a large fridge cabinet at the start of the kitchen which will block the stove, sink etc from being seen immediately, and also the front door opens left to right to also block it. I have realised though since living in the woop whops, no one visits.. kids come in and straight into kitchen anyway, the view from the lounge doors will take away from the clutter, I will be tidier, most of the mess (ie toaster etc) will be in the butler pantry and with no small kids at home now, I can at least tidy it if I hear a car on the drive!! But I do agree with your point..I hate it too...but the cabinet will be my saviour. 4. access to the main bedroom is a bit awkard, tucked around the corner of the liveing area and directly near the dineing table, could get a bit noisy for the bedroom occupants if others are still chatting around the table. The table will be moved forward and a side board will be against that bedroom/ dining room wall, (or an armoire with a computer in it ) so the view will be of furniture not the table as you come out of the master bedroom suite..woof! ..I had asked him to move the table over to the pantry wall..but alas, wasnt to be! That way no one will ever know there is a door there as it is tucked away and I also want my split air con above the door frame, cos I hate seeing them should hide it a bit...esp from the table and couches. as our kids are 7- 14 (and the 19 is overseas) any partying will be from me and hubby...but I know what you mean...re kids staying up later and we hearing them, hence no tv there..only in lounge/ play station room,,... far enough away..and their friends can exit via the garage! (cos they know what mum is like..I can hear a cricket fart 4 kms away...grrrrrrrrr) 5. Laundry is that little area next to the garage? Seems a small laundry for a such a large family home and has no direct light/ventilation/outside access - that could be a problem IMO it is in the 'hall' bit as you go into the house, there is a door into the house but no doors on the laundry..took them off..not really needed. The access is via a door to the clothesline area..(on plan) ...it will be glass for light and we will have a dog flap on it but no window in garage as such. Not sure if I need one as our garage door is usually up anyway in the day if home. The septic and water tanks are on the south side of the garage wall...wanted that all wall for them. do you think I need one? laundry is small, but that was the sacrifice for a small house. a 5 bedroom home should be about 265sq mets, (one of my original plans) and I shrunk it by 35sq ! eek I am using firth blocks, in manorstone..like oamaru stone, but cheaper http://www.firth.co.nz/project-inspirat ... lders.aspx titania joinery and sambuca horizon tiles. thank you so much for your comments..I do appreciate them. I too agree with them! and if you can think of a way to lessen at least one concern..that would rock! (the windows, long and narrow and high up in bathrooms, might be the way to go, thank you. even if it does open into the entrance..ha ha...at least it can be clear glass) Re: PIMP my plans ..please?! 8Jun 26, 2010 4:50 pm This was the original plan...7 bedrooms! 222sq mets (I added 8 sq mets to have WIR in bedrooms, and larger linen cupboards to make it 230 sqm) http://www.flickr.com/photos/48503166@N ... otostream/ dull facade http://www.flickr.com/photos/48503166@N ... otostream/ but hey....we cant all have a funky facade can we!??? small laundry so my smaller pantry in kitchen (with a cavity slider so cant see in it) is an appliance/ broom/ steam cleaner/ vacuum cupboard. thank you again for all your comments, keep em coming if you can see anything that stands out that is just 'not on' and will tweak the plan cheers Re: PIMP my plans ..please?! 9Jun 26, 2010 4:59 pm Kiaora. Good old Whangarei. oooh I so miss NZ. My family are from way up north. Ahipara. All the best with your build and look forward in seeing things progress. Re: PIMP my plans ..please?! 10Jun 26, 2010 5:21 pm wow, way up north! cousie bro area..ha ha fush and chups.......... Re: PIMP my plans ..please?! 11Jun 26, 2010 5:45 pm kiwi I have 5 kids and we have no money (cos of said 5 kids) I have absolutely nothing of value to add, but just wanted to say FIVE KIDS?? You're awesome.... Re: PIMP my plans ..please?! 12Jun 26, 2010 8:33 pm kiwi wow, way up north! cousie bro area..ha ha fush and chups.......... Yeah spot on. Oh I miss the pies. I never eat pies here but just love them there. The lamingtons and cakes you have there are the best with REAL cream. Re: PIMP my plans ..please?! 13Jun 27, 2010 1:25 pm kek kiwi I have 5 kids and we have no money (cos of said 5 kids) I have absolutely nothing of value to add, but just wanted to say FIVE KIDS?? You're awesome.... owww, thanks, that is very nice to hear. Thank you! Dollar Yeah spot on. Oh I miss the pies. I never eat pies here but just love them there. The lamingtons and cakes you have there are the best with REAL cream. and the fab ice cream..and all the flavours from cadbury...crunchie, black forest, trio, bubbles, dream, topdeck, caramello, rocky road... need I go on... Re: PIMP my plans ..please?! 14Jun 29, 2010 6:25 am Not much to add other than can you squeeze a couple of small north facing windows in the dining and lounge? Both of those have a small section of wall that would at least afford your a little bit of warmth from nor-east sun as it moves across in the morning. I know that everything else is custom built for you, and is the way that you want it and that you feel your family can live well with it, so well done =) Re: PIMP my plans ..please?! 15Jun 29, 2010 6:40 am I could pop some where the lamp / christmas tree will go. (and next to the armoire, on right) Good for some cross breezes too... thanks! Re: PIMP my plans ..please?! 16Jun 29, 2010 7:22 am Hi Kiwi, I lived in Whangarei for 2 years before coming to Melb. Originally from Invercargill. I moved from the cold to the tropics. If I ever went back the NZ it would definately be to Northland. Love your house plan. So much room and lots areas to get away from each other. The pic of your house on fliker looks really nice. Kay A balanced diet is chocolate in both hands. Melbourne West Our build viewtopic.php?f=31&t=34169 Landscaping viewtopic.php?f=19&t=51147 Re: PIMP my plans ..please?! 17Jun 29, 2010 10:39 am Thank you Kay, I am from christchurch and moved to northland (cos of the bay of islands...fantastic!) 3 yrs ago (via Sydney and Kent in the uk!! ha ha) Whangarei is a dump....(has to be said..), bar the town basin, which they really need to continue along the river cos it is MAGIC, I like Maungakaramea where we live here are some pics of the 1 acre and surrounding countryside... very englishy ay! (with the odd tropical fern) our drive will come off the shingle road. the fenced part is ours, rest farmland Re: PIMP my plans ..please?! 18Jun 29, 2010 10:45 am Re: Plans and photos of our land in NZ (I know, a gate crash 19Jun 29, 2010 10:50 am Re: Plans and photos of our land in NZ (I know, gate crashin 20Jun 29, 2010 11:21 am Kiwi , those pics are fabulous. The views you will have are great. I left Whangarei over 30 years ago and I still can picture all the different places. I had so much fun and alcohol in that place it wasn’t funny. I used to work at the telephone exch in the main street. Long gone now, no doubt. I loved all the little bays we used to go to swim and picnic. Ah, the memories. Kay A balanced diet is chocolate in both hands. Melbourne West Our build viewtopic.php?f=31&t=34169 Landscaping viewtopic.php?f=19&t=51147 Joe, it depends on your certifier but we are noticing the ones we deal with are really cracking down. So i would recommend you follow your approved landscaping plans to… 4 10989 Hi Simeon, Thank you for laying it down for us. Makes sense. Appreciate it very much. Have a nice day. Cheers 2 9034 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16291 |
