Browse Forums Bathrooms and Laundry Re: Awkward floor plan with corner spa bath 2Jun 18, 2010 5:17 pm You could change the laundry door to a sliding door which will save a lot of space - this is what we'll be doing. Your bathroom is a lot like ours in that we will have a door from the hall and also a door onto the deck. Sorry I can't offer much advice. Re: Awkward floor plan with corner spa bath 3Jun 19, 2010 10:01 am Just check on where the spa pump etc needs to go? I don't have one, so have no idea about these things, but the ones I've seen usually have a tiled extended hob to one side that conceals the spa workings. Re: Awkward floor plan with corner spa bath 4Jun 19, 2010 10:42 pm kek Just check on where the spa pump etc needs to go? I don't have one, so have no idea about these things, but the ones I've seen usually have a tiled extended hob to one side that conceals the spa workings. Hi Kek, The pump will be outside, it won't take space and it's easy to maintain it as well. No room for hobs in our case... hope this will work out somehow Re: Awkward floor plan with corner spa bath 5Jun 19, 2010 10:42 pm Almond~Eyes You could change the laundry door to a sliding door which will save a lot of space - this is what we'll be doing. Your bathroom is a lot like ours in that we will have a door from the hall and also a door onto the deck. Sorry I can't offer much advice. Cheers, We are considering sliding door as well... 3 3560 4 14277 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 4784 |
