Browse Forums Building A New House Re: Things you forget 81Jun 07, 2010 5:29 pm http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Things you forget 82Jun 07, 2010 9:00 pm If I was to win Lotto, I would build with a different builder, now to win lotto Re: 83Jun 08, 2010 8:34 pm http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Things you forget 85Jun 11, 2010 3:07 pm This thread is invaluable!! Thank you! We have only recently signed our contract so very early days for us but I'm desperately trying to think of something to add.... Anything that I had in mind has been mentioned but I'll be sure to come back as we build and notice things. At the very least I've bumped this thread up Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Things you forget 86Jun 11, 2010 3:32 pm If you are planning on getting your WIR done properly after handover make sure you ask the builder not to put in the rails etc. We forgot and its going to be a pain to take it all out. Re: Things you forget 87Jun 12, 2010 2:30 am Aaron & Erin Check the position of the man hole. Ours was in the laundry, above the wall where we wanted to put storage shelves against. We moved the manhole to the other side of the room so now that space is free for us to put shelves in up to ceiling height. We also moved the light switch to next to the door where we enter the house from the garage. For some reason the light switch was across the other side of the entry hall. So now you can turn the switch on/off from standing at the door. We have added the man hole in the garage. Someone else on here suggested it, as when a tradie comes to do work they can do it all from the garage and not from the inside of the house. Most will leave dirty footprints and finger prints on the man hole. All this can be concealed in the garage! great idea. Re: Things you forget 89Jun 12, 2010 7:10 pm Caught up with a friend of mine today who bought a house that was built 5 years ago (same builder as us). She mentioned their alfresco ceiling which is under the roof line is getting mouldy & believes they didn't use a proper outdoors material to do this and that they used the same material as the inside ceiling. I would never even have thought of checking this. Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Things you forget 90Jun 13, 2010 8:14 am draco76 - lights in the roof/ceiling cavity with the switch just in the manhole opening. makes it easier to see if there are any leaks in the roof Best way to have this wired in is for the power to be supplied on a flex lead. The reason for this is if your lights are wired into a circuit and you have that circuit off for maintenance or repiars, the lights won't work. Ensure the lead is well anchored at the fixed end in the ceiling and make the cord long enough so it can plug into at least two different circuits. Re: Things you forget 91Jun 13, 2010 10:51 am Wow, this thread is great! I completely forgot to add ceiling heating duct in the ensuite and bathroom! Will try and contact our CSC to see if it's still possible to add it now! Does anyone know how much PD charge to add ceiling heating duct in the bathroom? Also, is a garden tap a normal inclusion? I can't seem to find it in our house plan drawing? Thanks! Re: Things you forget 93Jun 13, 2010 11:15 am glockenspiel Wow, this thread is great! I completely forgot to add ceiling heating duct in the ensuite and bathroom! Will try and contact our CSC to see if it's still possible to add it now! Does anyone know how much PD charge to add ceiling heating duct in the bathroom? Also, is a garden tap a normal inclusion? I can't seem to find it in our house plan drawing? Thanks! You may not be able to add an extra duct, depending on the size of your heating unit and how many points oyu already have. I wanted three added, but could only do one unless we upgraded to a bigger unit. Can't remember the cost, but it was three years ago anyway, so probably not very helpful. The backyard outdoor tap should be marked on your plan with an asterisk kind of thing. Depending on the floor plan, the usual locations are near the laundry door or the rear of the garage. The front tap won't be marked - that will be wherever the meter ends up. I highly recommend adding an extra tap - or even two if your house is big. Garden hoses are never long enough.... We now have three in the back yard. One at the side, near our outdoor entertaining area, one behind the garage, and one right down the back of the house. Re: Things you forget 94Jun 13, 2010 8:58 pm Thanks Rowena & Kek! I found the garden tap! You're right, it's marked with an asterisk and is near the laundry door! I'll speak to our CSC next week regarding the additional duct, if it's not possible to add another one, do you think I should go with heater lights instead? Re: Things you forget 95Jun 13, 2010 11:38 pm This thread is great. Wish we'd found it earlier as we've just commenced the construction stage with the Big M. We've been told we cannot make any changes now. Has anyone else building with them been able to request changes after construction started? Thanks for sharing. http://glenn-and-denhs-tribeca.blogspot.com/ Handover: Thurs 9th June!!! Fixing: forever and ever and ever...... Lockup: late Feb 2011 Re: Things you forget 97Jul 08, 2010 12:56 am Here is a cheap tip that will you'll be glad you did. Before you get your drive way paved, lay a 4" pvc pipe under it so that you or your retic fitter can pass a water pipe through it when installing reticulation in your garden. Re: 98Jul 08, 2010 10:44 am oztish * Pay TV, TV and Phone points in every single room - you never know... dedicated Phone only points are such old tech TV points and Data sockets. If done properly (smart wired/ structured) they all end up in one place then there is no need to double up on foxtel points aswell and just having "phone" points is very limiting what you can achive in a House... basic spec for any house is 2 x data (CAT6) + 1 x TV (RG6) to most rooms but exceptions are office add extra 2 x data on a different wall Kitchen 2 x data one for phone other as network point one behind the fridge... HT/ major tv spots 4 x data 2 x TV Cabling for a video door intercomm, cabling for any video survalance either RG or IP based Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Things you forget 99Jul 08, 2010 11:05 am we didnt check windows on our final plan and they had moved in toilet , bathroom and bed 2 such a pain, but we signed off and they wouldnt let us move them. the brickies started today wonder if they would move them ever so slightly? Re: Things you forget 100Jul 08, 2010 1:14 pm Great thread guys! Thanks heaps for your tips. One thing my partner reminded me of was to install a mecidine cabinet in the ensuite/ bathroom. Especially if you only have a single vanity with limited storage space! http://allyslilcastle.blogspot.com/ Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11547 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8366 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6623 |
