Browse Forums Landscape & Garden Design Re: stone tile cladding for water feature 2Mar 23, 2008 7:10 pm Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: stone tile cladding for water feature 15Mar 25, 2008 10:44 pm royalblue **Phoenix** Ash, not that i'm worried about the iron spots, but do you know if this occurance would still occur if the stone is sealed prior to use??? "prevent it - not possible" Your query indicates what is a very common misconception about sealers. There are different kinds of sealers, but most of them are not a water-tight barrier. They cannot change the inherant characteristics of stone. Ash. Ok then Ash, can you recommend a sealer that would be water-tight for use in such an application??? Re: stone tile cladding for water feature 16Mar 25, 2008 10:52 pm Sorry, NO. Must admit, this may go beyond my experience on the topic, but I don't believe it is a practical objective to try to seal a stone water feature.
It would have to be some kind of rubber membrane. Why would you? Ash. Re: stone tile cladding for water feature 17Mar 26, 2008 9:58 am Another site worth looking at for the stone is:
http://www.leisurestone.com.au They are located in Melbourne. Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5756 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12185 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11244 |
