Browse Forums Heating, Cooling & Insulation Re: Safety of ducted central gas heating 6Jun 07, 2010 9:38 am I'd guess you can get some sort of air quality alarm installed if you were really concerned about it. Re: Safety of ducted central gas heating 7Jun 09, 2010 10:08 pm Just received a quote for Brivis high efficiency gas ducted heating unit (HX35I) plus Brivis 3 phase cooling coil and condenser (model 38CDA21B9 / 28IDA21). This is for installation in the first floor roof space. I'm a bit nervous about having this stuff in the roof cavity but I am sure is normal practice? The guys who quoted me are specialists and come highly recommended. Anyone else have this or similar installed? Re: Safety of ducted central gas heating 8Jun 12, 2010 4:53 pm Kratos Just received a quote for Brivis high efficiency gas ducted heating unit (HX35I) plus Brivis 3 phase cooling coil and condenser (model 38CDA21B9 / 28IDA21). This is for installation in the first floor roof space. I'm a bit nervous about having this stuff in the roof cavity but I am sure is normal practice? The guys who quoted me are specialists and come highly recommended. Anyone else have this or similar installed? We had gas ducted heating installed at our old place in 2001, and the unit was outside, as they always were, and the ducting run under the floor. When we moved into rented accommodation while building, we were mystified as to where the heating unit was...couldn't find it anywhere. We were surprised to discover it was in the roof space, then we learned that that's how it's done now, at least when you're on a slab. We had no problem there, nor have we in our new place, and the bulky unit isn't taking up valuable space outside. The only downside to it is the noise it makes when the gas ignites ....consider where you place it carefully. Above a bedroom probably isn't a great idea if the occupant is a light sleeper. You might not get much choice though, they're usually quite close to the manhole for easy access. Re: Safety of ducted central gas heating 9Jun 12, 2010 10:05 pm The large fan unit for our ducted RCAC exists in our roof space and you wouldn't know it is there. It sits on some kind of sprung mechanism. On the other hand, our old house had a ducted gas heater made a loud judder when switched on a produced a noticeable vibrating noise in the roof space when running. Re: Safety of ducted central gas heating 10Sep 17, 2010 8:58 pm If you're worried about it, get a carbon monoxide detector. Just like a smoke detector, but for gas in the home. It will go off if you have a leak. Recommended where I come from where ducted gas heating is the norm not the exception. http://cgi.ebay.com/FIRST-ALERT-EXPLOSI ... 23069a97b4 Re: Safety of ducted central gas heating 11Sep 17, 2010 8:59 pm Sorry, Australian link: http://www.kidde.com.au/utcfs/Templates ... 59,00.html Hi All, Our current 16 year old ducted gas heating is broken and needs an urgent replacement and appreciate any advise from the industry experts to make a decision for… 0 4188 Hi everyone. I am a single mother with little daughter, living in a small tourist town in WA Australia. I am thinking to install security screens to all the doors and… 0 39064 Hi, just need to ask if anyone build with Central Properties in Victoria. Thankd 0 4163 |
