Browse Forums Home Theatre & Automation 1 May 30, 2010 7:15 pm 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Carpet on the walls? 2May 31, 2010 3:19 am We're building The Albany 330E with Casa Design & Construction via National Builders Group See how we are going here: https://forum.homeone.com.au/viewtopic.php?f=31&t=32694 Re: Carpet on the walls? 4May 31, 2010 9:25 am Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Re: Carpet on the walls? 6May 31, 2010 2:10 pm 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Carpet on the walls? 8Jun 02, 2010 2:51 pm 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Carpet on the walls? 10Jun 02, 2010 7:11 pm 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Carpet on the walls? 11Jun 05, 2010 12:23 pm 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Carpet on the walls? 12Jun 06, 2010 7:31 am That's definitely much better. I myself will be (hopefully) building my new room soon and I am trying to get mine about 6.0L x 4.8W. But then I am actually hoping to have a little bit of room behind my seats (for access to the room from behind them, and to enable me to actually have my surround speakers set back behind me a little), and I really like a bit of width in the room too to allow the front left and right speakers plenty of distance between them and distance from the screen to them... Re: Carpet on the walls? 13Jun 06, 2010 1:48 pm The new room size sounds great. Not sure if I would be too keen on carpet on the walls, but that would be mainly on aesthetic grounds. Might be a bit much. We are just about to start building and will have a dedicated HT room. I will be using acoustically transparent material from a company in Melbourne (rimfabrics.com.au). Check out the Trilogy materials, which are about $15-$20 per 1 m length (1.88m x 1 metre). I am doing a complete room including ceiling for just over a thousand dollars. To attach the material, you could try a US company called fabricmate (www.fabricmate.com). Not a cheap fix but it has the benefit of being able to use acoustic products under the material. I think that if you carpet the whole walls you will find that the room becomes a bit 'dead' acoustically. Sound is a reflective medium. If you lose your off axis sound it will be a pretty dead room and would not be to my liking. It will certainly keep a lot of the sound in the room though. You can spend thousands just isolating and acoustically treating your room. In terms of acoustics, and also depending on your equipment, I would think that a couple of thousand is not too bad to get you going. Happy to chat if you want to PM me. I agree with what the other have said, but for me, I think carpet may deaden the room too much. Would be better to find a midpoint. Just my two cents. Cheers Greg. Re: Carpet on the walls? 14Jun 06, 2010 2:52 pm well im always up for a cheaper alternative, how thick is this material? are you just going to attach it onto the gyprock? 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Carpet on the walls? 15Jun 06, 2010 8:38 pm this is sort of what im after: http://ocau.com/pix/ixted http://ocau.com/pix/d74ao nothing too crazy, cept for the carpet or fabric on the walls.. 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Carpet on the walls? 16Jun 06, 2010 9:56 pm Hi there Firefox, The track runs at $1.95 per foot,so you would need to go around the ceiling perimetre top and bottom and then need 1-2 tracks running around the room to allow for the joining of the material. It quickly adds up but if you order complete boxes, you should get out for about $1000 in materials for the track plus about the same for the material. I am using the FS100 track, which is 1/2 inch which will allow a thin substrate material for acoustic treatments. Added to that, my room will be isolated with Green Glue whisper clips, which detatches the gyprock walls from the studs. This makes a massive difference in sound transmission out of the room. In terms of material thickness, I would check with the supplier as the materials are all different. The trilogy one is very similar to GOM material 701, which is what most of the guys on AVSForum generally use. Feel free to PM me and I can call you if you like. I don't like pushing products too much here..neither do the moderators! Best of luck Greg Re: Carpet on the walls? 17Jun 08, 2010 6:18 pm just heard back from the owner of that HT picture. for those interested the room is: 5.5m x 5m thanks greg, i have heard about excellent results from green glue, its certainly isnt cheap! lots of people on the avsforums wouldnt build a room without it! im keen to see how your setup goes, is it like a foam consistency? 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Carpet on the walls? 18Jun 08, 2010 8:04 pm ![]() just heard back from the owner of that HT picture. for those interested the room is: 5.5m x 5m thanks greg, i have heard about excellent results from green glue, its certainly isnt cheap! lots of people on the avsforums wouldnt build a room without it! im keen to see how your setup goes, is it like a foam consistency? Hi mate, My room is going to be 5.6 x 4.55 x 2.7m high. I will not be using Green Glue. I am using the whisper clips from the Green Glue company. They work a little differently and basically separate the gyprock from the studs to stop sound transmision. Green Glue is the actual adhesive that is a thick, viscous product that has some adhesive qualities (still needs to have drywall screws) but basically converts the energy created through sound vibration into low heat and then dissipates this heat. This conversion of energy stops the transmission of sound through to other parts of the home. That's about as simple as I can explain it. If you do a search on youtube you will find a stack of info on Green Glue. I think you may be ahead of us on the build. We are still waiting on Council permission. Almost there. Hope to start building within a month or so. I think that you will find so many hidden costs if you want to really go to town on your room. A home theatre is very different than a media room / TV room / Rumpus room. Everything is expensive, from lights, to sound proofing, through to cabling etc etc. The list goes on! Feel free to PM if you need any other info. Cheers Greg 1 16729 ![]() they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 7117 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 8322 |
