Browse Forums Landscape & Garden Design Re: Slopped Retaining wall 6Jun 04, 2010 4:30 pm Feeling your pain. My neighbours put up the dodgest retaining wall known to man and then wanted us to put the fence on it. We basically said no way- and after my builder told them that their fence was getting put in the too stupid basket and it would probably fall down within two years we won and put the fence on ground level. There is no way in hell I would want to look at that ugly thing everyday. Lisa- Finally in our house!!! Re: Slopped Retaining wall 7Jun 04, 2010 4:40 pm not sure if it is the case in all states but we were advised that if the retaining wall is only on their land then there is nothing you can do about it. You are permitted to put a fence up in front of it though. Re: Slopped Retaining wall 8Jun 04, 2010 4:47 pm Even though there will already be a fence sitting on top of that reaining wall? I can put up another fence? "Kind of like backing on to each other? I am going to take more pictures later today! Not happy Jan.. I am pretty sure that the retaining wall is on the boundary - they have knocked out our pegs to put it in! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slopped Retaining wall 9Jun 04, 2010 5:01 pm It appears they selected the quickest way to erect the wall rather than the best way. Given the side to side slope of the ground they should have stepped down a couple hundred mm per each section and kept each panel level but that would have entailed more digging and a spirit level. The end result you have is a wall that will do the job providing that: a: The posts have been set at the correct depths. and b: Each post and panel connect as per the manufacture's design. (It's a bit hard to tell this from your blog pictures) Overall it just looks bad because the posts are not standing up straight and the panels are not sitting level. Re: Slopped Retaining wall 10Jun 04, 2010 5:06 pm KnockItDown It appears they selected the quickest way to erect the wall rather than the best way. Given the side to side slope of the ground they should have stepped down a couple hundred mm per each section and kept each panel level but that would have entailed more digging and a spirit level. The end result you have is a wall that will do the job providing that: a: The posts have been set at the correct depths. and b: Each post and panel connect as per the manufacture's design. (It's a bit hard to tell this from your blog pictures) Overall it just looks bad because the posts are not standing up straight and the panels are not sitting level. How and who would I get to check this? Thanks for your reply Re: Slopped Retaining wall 11Jun 04, 2010 5:31 pm Cooped07 KnockItDown It appears they selected the quickest way to erect the wall rather than the best way. Given the side to side slope of the ground they should have stepped down a couple hundred mm per each section and kept each panel level but that would have entailed more digging and a spirit level. The end result you have is a wall that will do the job providing that: a: The posts have been set at the correct depths. and b: Each post and panel connect as per the manufacture's design. (It's a bit hard to tell this from your blog pictures) Overall it just looks bad because the posts are not standing up straight and the panels are not sitting level. How and who would I get to check this? Thanks for your reply Find out the manufacture and contact them to see if they can provide you with any specs on the wall system. They may also be the best place to start with getting someone to inspect the wall. Re: Slopped Retaining wall 12Jun 04, 2010 9:07 pm I certianly hope they don't expect you to help pay for that. Re: Slopped Retaining wall 13Jun 07, 2010 1:42 pm What about the last post on the right of the picture, the retaining wall is left 'leaning' out into the boundary of the two places next door (your right neighbour, and your rear neighbour's left neighbour) - it just looks like d-o-d-g-y construction work IMHO. Re: Slopped Retaining wall 14Jun 07, 2010 2:12 pm That's right it is very ******* & almost all the posts are leaning one way or the other. Can't find out any information about who made or built the wall. I think perhaps they did it them selves. I need to find out if they have done it completely on the boundary or in their own property.. Regardless though it looks ******* and I would hate for it to fall on top of my children! Re: Slopped Retaining wall 16Oct 17, 2010 3:06 pm Gosh! I really think that retaining walls give people the biggest HEADACHE!!!! Re: Slopped Retaining wall 18Oct 19, 2010 10:15 am That is a terrible job. The posts are not straight, and the wall is not straight How did they build it. I mean, the would have had to use a water level, how would they have made sure it was straight? Either the wall is not straight, or the house is not straight! Take a water level and see if the wall is out. Either way that last post looks totally whack. I cannot belive that job. Re: Slopped Retaining wall 19Oct 22, 2010 3:05 am Take a ruler and plumb bob too... Wouldn't that produce a collective lateral stress along the wall not being vertical? I would imagine it would want to "walk" downhill? The danger is collapse if enough top weight exceeds the soils capacity to anchor the last few risers. Reminds me of old railway platforms on abandoned lines. They don't last long once they start to move. Diagram explanation Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A very 2D representation. Assuming the last post resists the others will bunch up forcing a sideways or outward momentum. At that point all is lost, the wall has lost most of its strength and you have to start again. Its like a train wreck in slow motion. mass would be a % of the total weight (angle / 3.14) So in layman terms - its gonna stuff up and it could be next week or next year. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5346 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16204 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6948 |
