Browse Forums Bathrooms and Laundry 1 May 26, 2010 11:52 pm Hi all, new to this forum and happy to be here. We're about to start a build and we're blaming Kevin McCloud… I have a BCA question regarding which way bathroom doors should open. I know that a loo in it's own cubicle should have a door that opens out, slides or can be removed, but does the same rule apply to a bathroom with a loo in it? Thanks, Markie ps we're in Victoria If you're not living on the edge you're taking up too much space… Re: Bathroom doors and the BCA 2May 27, 2010 8:04 am markielinhart a loo in it's own cubicle should have a door that opens out Why don't you get it straight from the horse's mouth (I did): http://www.abcb.gov.au I had to wait a day for a call back, but the person I spoke to was brilliant. Re: Bathroom doors and the BCA 3May 27, 2010 8:49 am The same would not apply to a bathroom with a toilet in it unless it was a very small room - its only if the toilet is so small that it would not be able to be opened in an emergency (ie because the person collapsed on the toilet would be blocking the door from opening in) So I guess it wouldnt apply to a larger room with just a toilet either - but in practice it is usually toilets in their own small room. Re: Bathroom doors and the BCA 4May 28, 2010 7:58 am Thanks all. We've fixed the problem by switching the loo and handbasin positions. This puts the loo more than 1.5 metres from the doorway - the sticking point apparently If you're not living on the edge you're taking up too much space… I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10048 Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10925 we have a standard size and often we have a lot of variety to choose 0 3576 |
