Browse Forums Home Theatre & Automation Re: Slimdevices squeezebox duet (by Logitech) anyone? 4Mar 19, 2008 11:04 am Looks great!
Good luck getting one though... They are not available in Australia as yet. I have rang numerous sources to acquire one today but to no avail I am afraid. I will let you know what they are like once they are available though Re: Slimdevices squeezebox duet (by Logitech) anyone? 5Mar 19, 2008 3:24 pm Rodda Yeah, spec-wise the biggest difference between this Logitech system and the Sonos system is that Sonos give you the option of a version of their 'ZonePlayer' (equivalent of the Squeezebox Receiver) with a built-in 50W x 2 stereo amplifier, whereas Logitech force you (for now at least) to provide your own stereo amplifier for each zone/Squeezebox Receiver (which means you will need to connect two separate devices to power in every zone). i see. the plan is that we wanna have ceiling speakers in the ensuite, and then run the wire to the master br, then hook it up to the logitech. is there ceiling speakers that come with built-in amp? we might also include pre-wiring ceiling speakers points in other rooms (kitchen, lounge, outdoor) in the electrical appointment tommorow and then run the stereo plug on the wall plate in each zones. will that be sufficient to run the squeezebox systems in the future? mattwalker I have rang numerous sources to acquire one today but to no avail I am afraid. I will let you know what they are like once they are available though cheers, keep us posted Re: Slimdevices squeezebox duet (by Logitech) anyone? 6Mar 19, 2008 5:47 pm Hi Jinroh (intersting film)...
There are no in-ceiling speakers that I'm aware of that come with a built in amp (and if there were, they'd either be expensive or crap!)... Basically, for each Zone you will need the following: 2 x speakers in the room/zone where you want to hear the music, either in-wall/in-ceiling, bookshelf or even floorstanding speakers ** fed by speaker cable from a stereo amplifier ** (this amplifier can be located anywhere) 1 x stereo amplifier (needs to plug into power somewhere) ** fed by analogue or digital audio interconnect cable from the Squeezebox Receiver ** (this Squeezebox Receiver can be located anywhere) 1 x Squeezebox Receiver (needs to plug into power somewhere) ** network connected to your PC or PC-based music server/source, either wireless or wired (Cat5E) - wired is faster and not prone to any signal degredation due to obstacles etc.) ** (this PC or PC-based music server/source can be located anywhere) As you can see, some cable runs (including the power mentioned) are inevitable. The sooner you accept that, the sooner you can get on with designing the solution that best works for you... Re: Slimdevices squeezebox duet (by Logitech) anyone? 7May 15, 2008 3:28 pm jinroh cheers, keep us posted Consider your self posted!!! see here: http://forum.homeone.com.au/viewtopic.php?p=63630#63630 Re: Slimdevices squeezebox duet (by Logitech) anyone? 9May 20, 2008 8:04 am jinroh,
I paid $550 inc delivery to Melbourne... np on the update Wish you all the best. Once you signed the contract, they will find millions excuses to charge you. And have seen their sites unfinished for a long time. 4 24965 As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 18007 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10132 |
