Cabin the other option is ..... Crank up on the inside the house speakers - so you can hear it outside
Steve
Browse Forums Home Theatre & Automation Re: Outdoor Speakers - Options Available? 25Mar 18, 2008 3:02 pm Hi Mike. Sorry for the delay in replying, I've just come back from being away for a few days...
You actually don't need much more than say 40WRMS per channel, really, although you might find an amp with up to 100WRMS per channel that's still well within your budget... Just remember, if you think you're likely to want to 'crank' the system every now and then, make sure that whatever amp you get your speakers can handle that power, or near to it (actually, it's OK to have an amp that has a little more power in reserve so you don't have to push it to it's limit to get the power output you want...) ie. if your amp can put out 100WRMS then your speakers really need to handle as close to that (more won't hurt) as possible. If you drive speakers of low power handling with a more powerful amp all you have to do is turn it up a bit too much (this point varies, depending on your equipment) and you really can blow your speakers up!. Keep this in mind - one of the main areas you compromise on, with in-wall/in-ceiling speakers, when spending less money tends to be the power handling! When looking around at these speakers pay attention to this figure (I see many with power handling figures around 30WRMS, whereas the in-wall/in-ceiling speakers we tend to use are mostly in the 60-80-100+ WRMS range - with prices to match ). So, considering you want to go a bit loud every now and then, look at in-ceilings in the 40-50 (maybe 60) WRMS range, and and amp in the 50-70WRMS range (respectively).... See how you go... Re: Outdoor Speakers - Options Available? 26Mar 30, 2008 1:40 am McReidy Thanks for all you help gents.. I think I will go with the speakers I linked to earlier. Any thoughts on an entry level amp with the A (indoor), B (outdoor) , A+B (in & out) functionality? i have spent some time looking at simple zone amplifiers to help me decide on how i should pre-wire the speaker cables. these are what i've found so far: http://www.aaronhifi.com.au/product.php?prod_id=51 or: http://www.sonance.com/products/electronics/detail/234 the sonance seems to suit me best as it provide output for 3 pairs of speakers (2 pairs for indoor dining/living/kitchen area, and a pair for alfresco). it's nice that both amps got auto on (signal-sensing) feature, so less button to push to operate the system . but i'm not sure if there is sonance dealer locally. does anyone know one in melb? i'm also looking to have in-ceiling speakers in the ensuite, and found this in-wall amp with a nice wall-plate controller: http://www.actionhardware.co.uk/sales/product_info.php?cPath=119_153&products_id=1172&osCsid=a385e14724fbe20f7dedf4cf53cb1a5c the plan is to have the wall-plate installed in the bedroom and connected to the music source (eg. CD, PC, etc). same problem as above, not sure if they can post it to oz. also, it's rated at 20W RMS per channel. might not be sufficient to deliver the music while having a shower Re: Outdoor Speakers - Options Available? 27Mar 30, 2008 9:43 am Hi Jinroh (have I already mentioned that's an interesting nickname?).
I hate to burst your bubble here, but I think all three of the products you've listed above are not suitable. Basically, the two 'zone' amps you chose are part of larger systems and will not have much functionality, if they are usable at all on their own (they don't have input selectors meaning that is controlled by another component upstream. The Sonance one doesn't even appear to have a volume control meaning again, that's controlled by another component in the system). P.S. Sonance is quite 'high-end' and has a price tag to match. The other product, the 'in-wall' amp, is a: under-powered, and b: English which means it's designed to work with their standard of electricity supply (so may not be perfectly at home in our homes). 1 (obviously) or 2 'zones' is easy to do - all you need is ANY stereo (or surround) amplifier or receiver that has a 2nd or 'B' pair of speaker terminals (as the amp will control all of it's inputs, and it's volume, for both zones). Doing more than 2 zones from 1 central solution puts you into the genuine multi-room arena... Now, if you want an all-in-one box that will give you 3 zones, where you can select between 3 input sources in any of the 3 zones and (natch) control the volume, gives you 60WRMS x 6 (Marantz quality too) which is about right on the money given what's been said already in this thread, and includes it's own IR remote control (which means you can then also run a simple IR repeating system with an IR receiver in each zone if you like), then I challenge you to find a better product than the Marantz ZS-5300: http://www.qualifi.com.au/index.jsp?ref ... duct=50714 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 30109 Natural stone tiles like slate, travertine, and limestone add a timeless, elegant look to… 0 28199 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 2393 |
